技术
IEEE 802.3 10Base-T IEEE 802.3u 100Base-TX IEEE 802.3u 100Base-FX
IEEE 802.3ab 1000Base-T
IEEE 802.3z Gigabit Ethernet Fiber
IEEE 802.3af Power over Ethernet
IEEE 802.3at High Power PoE with 2-Event classification
IEEE 802.3x flow control and back-pressure
性能
64bytes ~ 9Kbytes jumbo frame
10Mbps -14880 PPS
100Mbps-148800 PPS
1000Mbps -1488000 PPS
PPS:每秒封包数量, 64Bytes封包长度
界面 |
5个1000Mbps RJ-45自适应MDI/ MDI-X,自动协商功能,包含4个IEEE 802.3af/IEEE 802.3at以太网供电端口ports
1个SFP插槽,支持千兆SFP模块或百兆SFP模块。可通过DIP拨码开关选择
(需重启)
冗余电源输入支持极性反接保护,可拆卸6-pin接线端子
100Base-TX: 2-pairs EIA/TIA568-B UTP/STPCat.5e/ Cat.6 cable
1000Base-T: 4-pairs EIA/TIA568-B UTP/STPCat.5e/ Cat.6 cable
通过6-pin DIP拨码开关启动或关闭端口断连或掉电报警
正常状态 (报警关闭) – 建立一个开路
异常情况(报警启动) – 建立一个回路
Power1(绿灯)/Power2(绿灯), AlarmActive (红灯)
Ethernet Link/Activity (绿灯亮/绿灯闪烁),
PoE powering (黄灯亮), SFPport: Link (绿灯亮)
PoE |
Alternative-A(Data Pair Power feeding): Port 1~4 , V+ (3,6) V- (1,2)
IEEE 802.3af和IEEE 802.3at 2-Event
每端口最高输出30W,整机输出功率最高110W(75°C)
PoE在75°C/95%温湿度环境下:
DC 12V/ 60W (Maximum) output, Inrush current 7.53A DC 24V/ 110W (Maximum) output, Inrush current 6.01A DC 36V/ 110W (Maximum) output, inrush current 3.68A
电源需求 |
DC 12V或DC 24V, 输入范围: DC12~36V
极性反接保护和过流保护
10 Watts / DC 24V(75°C环境温度无PoE负载)
机械规格 |
144mm (H) x 55 mm (W) x 105mm (D)
(不含导轨夹)
工作环境 |
40~75°C / 110W PoE loading (DC 24V/ 36V)
通过认证 |
满足IEC 60950-1
电源外壳间,网口外壳间DC 2.12KV Hi-pot 隔离保护
IEC/EN 61000-6-4, CISPR 16-1-2/ -2-1/-2-3, CISPR 22, FCC ClassA, C
IEC/EN 61000-6-2
IEC 61000-4-2 ESD: Contact 6KV /Air Con. 8KV IEC 61000-4-3 RS: 80M~1Ghz /20V, 1.4~2Ghz/3V, 2~2.7Ghz /1V
IEC 61000-4-4 EFT: L-L/L-N 2KV, Signal 2KV
IEC 61000-4-5 Surge: L-L/1KV, L-N/2KV, Signal I/O 1KV
IEC 61000-4-6 CS: 0.15M~80Mhz / 10V
IEC 61000-4-8 PFMF: 30A/m Cont. 300A/m 1~3S.
IEC /EN 60068-2-6 vibration: 10~150Hz, 20m/s2 (2.04g), 20 sweeps / per axis.
IEC /EN 60068-2-27 shock: 50g acceleration, 11ms duration, Half –Sine wave
