技术 |
| Wireless: IEEE 802.11a/b/g/n for Wireless LAN IEEE 802.11i Wireless Security Ethernet: IEEE 802.3 for 10BaseT IEEE 802.3u for 10/100Base-TX IEEE 802.3ab for 1000BaseT IEEE 802.3at for Power over Ethernet IEEE 802.1D Spanning Tree Protocol IEEE 802.1Q for VLAN Highest Data Rate: IEEE 802.11b: 11Mbps IEEE 802.11a, g: 54 Mbps IEEE 802.11n: 300Mbps @ 40MHz |
界面 |
| 2个 10/100/1000Base-T RJ-45 (JetWave 3320) 2个 10/100/1000Base-T M12 (JetWave 3320-M12) 端口1满足IEEE 802.3at PoE 以太网供电标准 供电:4-pin,冗余直流输入 |
| 1x RS-232/422/485, 2-pin DIP拨码开关用于加载120ohm长距离终端电阻,使用远距离RS485通讯 |
| 1xDigital Input, 0: 3V max., 1: 11V~ 30VDC 1xRelay Output, 1A@24VDC |
| SMA type for 3G/GPRS, WIFI |
性能 |
| 5GHz Brand: (802.11n WIFI) FCC: 5.170~5.250GHz, 5.735~5.835GHz CE: 5.170~5.250GHz (可编程,用于其他5G) 2.4GHz Brand: (802.11n WIFI) FCC : 2.412~2.462GHz CE : 2.412~2.472GHz (依不同国家法规) |
| 802.11a/n: OFDM (BPSK, QPSK, 16-QAM, 64QAM) 802.11g/n: OFDM (BPSK,QPSK,16-QAM,64QAM) |
| 5.8GHz Brand: 21dBm@ 802.11a/n HT20 (MCS0/8, 5180MHz) for FCC 23dB EIRP for ETSI 301 893 (Band 1) 25dB EIRP for ETSI 301 893 (Band 4) 2.4GHz Brand: 21dBm at 802.11g/n HT40 (MCS0/8, 2422MHz) for FCC 20dB EIRP for CE (ETSI 300 328) (依不同国家法规) |
| 802.11a: -82dBm@6Mbps,1Rx; -95/-91dBm@6Mbps, 2Rx; -65dBm@54Mbps,1Rx; -79/-75dBm@54Mbps, 2Rx; 802.11g: -82dBm@6Mbps,1Rx; -95/-91dBm@6Mbps,2Rx; -65dBm@54Mbps,1Rx; -80/-76dBm@54Mbps,2Rx 802.11a/n HT20: -82dBm@MCS0,1Rx; -95/-91dBm@MCS8,2Rx; -64dBm@MCS7,1Rx; -77/-73dBm@MCS15,2Rx 802.11a/n HT40: -79dBm@MCS0,1Rx; -91/-87dBm@MCS8,2Rx; -61dBm@MCS7,1Rx; -74/-70dBm@MCS15,2Rx 802.11b/g/n HT20: -82dBm@MCS0,1Rx; -95/-91dBm@MCS8,2Rx; -64dBm@MCS7,1Rx; -77/-73dBm@MCS15,2Rx 802.11b/g/n HT40: -79dBm@MCS0,1Rx; -90/-86dBm@MCS8,2Rx; -61dBm@MCS7,1Rx;-74/-71dBm@MCS15,2Rx |
电源需求 |
| GSM/GPRS/EDGE: Quad band, 850/900/1800/1900MHz UMTS/HSPA : Five band, 800/850/900/1900/2100MHz |
| PS 384kbps DL/ 384kbps UL |
*参阅用户手册了解更多详细规格 |
电源需求 |
| Ethernet 1: 满足IEEE802.3at PoE 标准 |
| 2/4-pair UTP/STP Cat. 5E 线缆(100m) |
| Max. 10 Watts @ DC 48V,依据Radio TX power |
标配WIFI天线属性 |
| 标配天线5G 3.57dBi,2.4G 2.63dBi |
配置 |
| Web GUI, Korenix View Utility, SNMPv2c/v3, IPSetup, DHCPServer/Client, Management VLAN, Configuration Backup/Restore, Reload Default |
| 系统:Bridge 或Router 无线:AP, CPE, WDS-AP, WDS-Client |
| Radio Bandwidth Control, Channel, Output Ratio, Antenna number, 距离(M) |
| Multiple SSID, Radio On/Off, SSID Broadcast, VLAN ID, Client number, Wireless Isolation |
| Incoming/Outgoing Traffic Limit |
| 静态, DHCP, LAN/WAN IP, IP/Port Filtering |
| 串口模式RS-232/422/485, 波特率, 串口参数, TCP Server, TCP Client, UDP…等. (JetWave 3300系列) |
| 3G连接,状态,GPS定位, (Phase 2), LAN to 3G/ WIFI Redudnant (Phase 2) |
安全 |
| HTTPS, SSH, 802.1x, MAC Address ACL |
| WEP 64/128/152 bits, WPA-PSK (TKIP), WPA2-PSK/EAP (IEEE 802.1x/RADIUS, TKIP and AES) |
机械规格 |
| 149 mm(H) x 120.6 mm(D) x 74 mm(W) |
工作环境 |
可选附件 |
| 天线的安装面板: 外置天线: RG316 Cable, L=90cm, SMA Male Reverse to SMA Female Reverse |
通过认证 |
| CE, FCC part 15B Class A 铁道 EN50121-4 EMC认证 |
| EN 300 328, EN 301 893 EN301 489-1/17(WIFI)/24(3G) EN301908-1 |
可选附件 |
| Used for Celling-/Wall-mounting |
| 扩展无线线缆: RG316 Cable, L=90cm, SMAMale Reverse to SMAFemale Reverse |
