技术 |
| IEEE 802.3 10Base-T Ethernet IEEE 802.3u 100Base-TX Fast Ethernet IEEE 802.3ab 1000Base-TX IEEE 802.3x Flow Control and Back-pressure IEEE 802.1p class of service IEEE 802.1Q VLAN and GVRP IEEE 802.1D-2004 Rapid Spanning Tree Protocol (RSTP) IEEE 802.1s Multiple Spanning Tree Protocol (MSTP) IEEE802.3ad Link Aggregation Control Protocol (LACP) IEEE802.1X Port based Network Access Control IEEE802.1AB Link Layer Discovery Protocol |
性能 |
| 10M Ethernet:14,880pps 100M Fast Ethernet :148,800pps |
| 典型: 64 bytes~1536 bytes 启动Jumbo Frame: 最高达9,216bytes |
网管 |
| Cisco-Like CLI, Web, SSL, SSH, Korenix View, Backup/Restore, DHCP Client, 热启动,恢复出厂设置, Admin password, Port Speed/Duplex control, 状态显示, 数据统计, MAC地址列表显示, Static MAC, Aging time, Dual Firmware images |
| 链路层发现协议用于记录相邻网络设备的拓扑连接和管理信息 |
| MIB-II, Bridge MIB, VLAN MIB, SNMP MIB, RMON和Private MIB |
| 支持静态聚合和802.3ad LACP动态聚合, 最多8个聚合组, 每个聚合组包含2-8个端口 |
| IEEE802.1Q VLAN, GVRP. 最多255个VLAN组 |
| 可将下端端口分割成isolated/community VLAN,仅与上连端口相通 |
| 每个端口支持4个优先级,支持IEEE802.1p COS及 Layer 3 TOS/DiffServ |
| IGMP Snooping V1/V2 用于多播过滤及IGMP Query |
| 可使用Radius账号/密码登入,可与Radius服务器做认证 |
| 使用server/client模式记录相关事件信息 |
网络冗余 |
| IEEE 802.1s MSTP, MSTP Instance可与VLAN整合 |
| 802.1D-2004 RSTP, 向下兼容传统STP协议 |
| Korenix冗余环网技术,包括Rapid Super Ring, Rapid Dual Homing, TrunkRing, MultiRing |
| 在一台交换机上串接一个或多个环网.最多支持9个100M环 |
界面 |
| 10/100Base-TX: 16个RJ-45端口, 自适应MDI/MDI-X, 自动协商 100Base-FX: 2个SFP支持热插拔 |
| 10Base-T: 2-pair UTP/STP Cat. 3, 4, 5 cable (100m) 100 Base-TX: 2/4-pair UTP/STP Cat. 5 cable (100m) |
| 系统: Power 1, Power 2, Ringmaster(绿灯), Relay 1, Relay 2, Ring Failure (红灯) 10/100 RJ-45: Link / Activity (绿灯/绿灯闪烁) Full Duplex /Collision (黄灯/黄灯闪烁) 100M SFP: Link/Activity (绿灯/绿灯闪烁) |
| RJ-45 type, Pin: (2: TxD, 3: RxD, 5:GND) |
电源需求 |
机械规格 |
| 137mm(H) x 96mm (W) x 129mm (D) |
工作环境 |
通过认证 |
| FCC Class A, CE/EN55022. Class A |
| EN61000-4-2, EN61000-4-3, EN61000-4-4, EN61000-4-5, EN61000-4-6, EN61000-4-8 |
