苏州迅鹏 高温铂铑热电偶WRP2-130
高温铂铑热电偶 迅鹏WRP2-1301、应用 适用于各种生产过程中高温场合,广泛应用于玻璃及陶瓷及工业盐浴炉等测温。
产品分类:物联网 仪器仪表 感知层 现场仪表 温度仪表 热电偶 温度传感器
品牌:苏州迅鹏
高温铂铑热电偶 迅鹏WRP2-130
1、应用
2、主要技术参数
电气出口:M20x1.5,NPT1/2
精度等级:I 、 II
防护等级:IP65
偶丝直径:Φ0.5
公称压力:常压
3、型号及规格
型 号 | 分 度 号 | 测温范围℃ | 保护管材料 | 热响应时间 | 规 格 | |
d | L x l | |||||
WRP-130 WRP2-130 | S | 0-1300 | 高铝质 | <150S | Φ16 | 300x150 350x200 400x250 450x300 550x400 650x500 900x750 1150x1000 1650x1500 2150x2000 |
WRP-131 WRP2-131 | <360S | Φ25 | ||||
WRQ-130 WRQ2-130 | R | 0-1300 | <150S | Φ16 | ||
WRQ-131 WRQ2-131 | <360S | Φ25 | ||||
WRR-130 WRR2-130 | B | 0-1600 | 刚玉管 | <150S | Φ16 | |
WRR-131 WRR2-131 | <360S | Φ25 |
1) 热电偶I级按协议订货;
防爆热电偶/热电偶
WRN-240 WRN2-240 WRE-441 WRE2-441 WRE-241 WRE2-241
WRN-241 WRN2-241 WRE-440 WRE2-440 WRE-240 WRE2-240
WRN-440 WRN2-440 WRN-441 WRN2-441
防爆热电阻/热电阻
WZP-140 WZP2-140 WZP-441 WZP2-441 WZP-341
WZP-240 WZP2-240 WZP-241 WZP2-241 WZP-141 WZP2-141
WZP-340 WZP2-340 WZP-440 WZP2-440 WZP2-341
一体化防爆温度变送器/带温度变送器防爆热电偶
WRN-240M WRN-240S WRE-240M WRE-240S WRE-441M WRE-441S WRN-441S
WRN-340M WRN-340S WRE-340M WRE-340S WRN-441M
WRN-440M WRN-440S WRE-440M WRE-440S WRN-241M WRN-241S WRE-241M
WRN-341M WRN-341S WRE-341M WRE-341S WRE-241S
一体化防爆温度变送器/带温度变送器防爆热电阻
WZP-240M WZP-240S WZP-340M WZP-340S WZP-441M WZP-441S
WZP-440M WZP-440S WZP-341M WZP-341S WZP-241M WZP-241S
温度变送器模块/温度变送器
SBWR-1000 SBWZ-1000 SBWR-1001 SBWZ-1001 SBWR-1002 SBWZ-1002
SBWR-1006 SBWZ-1006 SBWR-1031 SBWZ-1031 SBWR-1034 SBWZ-1034
SBWR-1036 SBWZ-1036
端面热电阻
WZCM-201 WZPM-201
耐磨热电偶/热电偶
WRN-230NM WRE-230NM WRN2-230NM WRE2-230NM
WRN-630NM WRE-630NM WRN2-630NM WRE2-630NM
耐磨热电阻
WZP-230NM WZP2-230NM WZP-630NM WZP2-630NM
多点热电偶
WRN-230D WRE-230D WRN-430D WRE-430D
多点隔爆热电偶
WRN-240D WRE-240D WRN-440D WRE-440D
防腐热电阻
WZPF-130 WZP2F-130 WZPF-430 WZP2F-430
微细铠装热电偶 WRNK-191S WREK-191S
压簧固定热电偶WRET-01
直角弯头热电偶
WRN-530 WRN2-530 WRE-530 WRE2-530
WZP-120,WZP-121,WZP-130,WZP-131,WZP2-120,WZP2-121,WZP2-130,WZP2-131,
WZC-120,WZC-130
WZP-220,WZP-221,WZP-230,WZP-231,WZP2-220,WZP2-221,WZP2-230,WZP2-231,
WZP-221A,WZP-221A,WZC-220,WZC-230,WZC-220A
WZP-320,WZP-321,WZP-330,WZP-331,WZP2-320,WZP2-321,WZP2-330,WZP2-331,
WZC-320,WZC-330
WZP-420,WZP-421,WZP-430,WZP-431,WZP2-420,WZP2-421,WZP2-430,WZP2-431,
WZP-420A,WZP2-420A,WZC-420,WZC-430
WZP-621,WZP-621A,WZP-631,WZP2-621,WZP2-621A,WZP2-631
WZP-002,WZP-003,WZP-003A
WZP-010,WZP2-010,WZP-011,WZP2-011,WZC-010A,WZC-035S,WZC-001
WZC-200,WZP-260,WZP2-260,WZPM-267
WZP-269,WZP2-269,WZC-269,WZP-270,WZC-270,WZP-280
WZC-190,WZC-890J
WZP-892,WZP2-892
为什么解决PLC系统干扰问题优选信号隔离器
迅鹏浅析流量积算仪和定量控制仪的区别与联系
苏州迅鹏XP3018模拟量输出模块
苏州迅鹏RS485采集模块
苏州迅鹏XP2006远程I/O模块
