桦汉科技CEB-3853-W100 3.5寸主板
2020/3/16 13:30:11
Intel® Celeron® 3855U Processor 处理器,2 x LAN, 6 x USB,支持 Mini PCIe、M.2 SSD扩展,3.5寸主板
产品分类:嵌入式系统 嵌入式主板
品牌:桦汉科技
Intel® 第六代Skylake U双核处理器,HDMI/LVDS,2 x LAN,6 x USB,2 x M.2, 1 x MiniPCIE, 2 x COM, 3.5寸主板。采用Intel® 双核处理器, 双千兆网卡, 宽温宽压,支持Watch dog功能,15W低功耗,可以使用在有无风扇需求的系统整机中以及工业嵌入式控制等领域。
■ 特性 | ||
■ 规格 Specification | ||
处理器 Processor | Intel® Celeron® 3855U Processor(1.6 GHz) | |
内存 Memory | 1 x DDR4 1866/2133/2400MHz SODIMM, up to 16 GB | |
存储 Storage | 1 x SATA 3.0, 1 x M.2 2242(support SSD) | |
显示 Display | Intel® HD Graphics 510 | |
网口 Ethernet | 1 x RJ45 Intel® I211AT (10/100/1000 Mbps) 1 x RJ45 Intel® I219-LM GbE (10/100/1000 Mbps) | |
音频 Audio | Realtek® ALC269Q HD Audio Codec | |
BIOS | AMI UEFI BIOS | |
外部接口 Rear I/O | 2 x RJ45 2 x USB 2.0, 2 x USB 3.0(Support USB SR Pro.) 1 x RS232/422/485 1 x HDMI: max resolution up to 4096 x 2160 1 x Line out&Mic in(二合一) 1 x Remote | |
内部接口 Internal I/O | 1 x RS232 1 x LVDS: max resolution up to 1920 x 1200 2 x USB 2.0 pin header 1 x 8 bit GPIO 1 x Touch (1 x 9 pin header) 1 x F_Panel (power LED, HDD LED, power button, reset button) 1 x DC IN pin header | |
扩展接口 Expansion | 1 x M.2 2230 (for WIFI, PCIE&USB2.0信号) 1 x Mini-PCIe (for WiFi/3G/4G) 1 x SIM | |
环境 Environment | 操作温度: -20℃ ~ 60℃ 存储温度: -40℃ ~ 85℃ 操作湿度: 5% ~ 90% 存储湿度: 5% ~ 95%, 非凝结状态 | |
电源输入 Power Input | 9-36V DC | |
尺寸 Dimensions | 3.5" (146 x 105mm) | |
操作系统OS | Windows 7/8/10, Linux |
■ 订购清单 | ||
类型 | 型号 | 描述 |
标配 | CEA-PW12-CAB0 | 1xDC in, 1x4P, 120mm |
选配 | CEA-6203-FAN0 | Skylake-U CPU Fan module |
CEA-CM15-CAB9 | 1xCOM, 2x5P,150mm, blue | |
CEA-US20-CAB9 | 2xUSB,2x5P, 200mm,black | |
CEA-SA15-CAB0 | 1xSATA, 7+4P, 150mm, w/o lock, 90°/90° | |
CEA-RM03-CAB0 | 1xPhoenix conn(5.00), 30mm, female | |
CEA-3COM-1F2N | I/O expansion card, 3 x COM | |
CEA-2LAN-GBE0 | I/O expansion card, 2 x LAN(Intel 211AT) | |
CEA-1PCI-PCIE-CEP | Riser card, PCI+PCIe X1 | |
CEA-2PCI-CEP | Riser card, 2 x PCI | |
CEA-1PCI-CEP | Riser card, 1 x PCI | |
备注:CEA-1PCI-PCIE-CEP PCIe信号与主板M.2 2230共用 |
桦汉科技产品矩阵再扩大,全新升级的IPC-310工控机满足更多场景应用
新品速递|工业扩展型触摸一体机,实现工业应用的无限可能!
凭实力“出圈”,桦汉科技入选市级示范智能车间!
面对制造业的严重内卷,桦汉科技也能迎难而上!
