桦汉科技CEB-6X03-W100 3.5寸主板
Intel®Sky Lake i3-6100U/i5-6200U/i7-6500U 处理器 ,2 x LAN, 6 x USB,支持 Mini PCIe、M.2 扩展,3.5寸主板
产品分类:嵌入式系统 嵌入式主板 3.5寸
品牌:桦汉科技
Intel® 第六代Skylake U双核处理器,HDMI/LVDS,2 x LAN,6 x USB,2 x M.2, 1 x MiniPCIE, 2 x COM, 3.5寸主板。采用Intel® 双核处理器, 双千兆网卡, 宽温宽压,支持Watch dog功能,15W低功耗,可以使用在有无风扇需求的系统整机中以及工业嵌入式控制等领域。
■ 特性 | ||
■ 规格 Specification | |
处理器 Processor | Intel® 6th Core™ i3-6100U Processor(2.3 GHz) Intel® 6th Core™ i5-6200U Processor(2.3 GHz) Intel® 6th Core™ i7-6500U Processor(2.5 GHz) |
内存 Memory | 1 x DDR4 1866/2133/2400MHz SODIMM, up to 16 GB |
存储 Storage | 1 x SATA 3.0, 1 x M.2 2242(support SSD) |
显示 Display | Intel® HD Graphics 520 |
网口 Ethernet | 1 x RJ45 Intel® I211AT (10/100/1000 Mbps) 1 x RJ45 Intel® I219-LM GbE (10/100/1000 Mbps) |
音频 Audio | Realtek® ALC269Q HD Audio Codec |
BIOS | AMI UEFI BIOS |
外部接口 Rear I/O | 2 x RJ45 2 x USB 2.0, 2 x USB 3.0(Support USB SR Pro.) 1 x RS232/422/485 1 x HDMI: max resolution up to 4096 x 2160 1 x Line out&Mic in(二合一) 1 x Remote |
内部接口 Internal I/O | 1x RS232 1 x LVDS: max resolution up to 1920 x 1200 2 x USB 2.0 pin header 1 x 8 bit GPIO 1 x Touch (1 x 9 pin header) 1 x F_Panel (power LED, HDD LED, power button, reset button) 1 x DC IN pin header |
扩展接口 Expansion | 1 x M.2 2230 (for WIFI,PCIe&USB2.0信号) 1 x Mini-PCIe (for WiFi/3G/4G/mSATA) 1 x SIM |
环境 Environment | 操作温度: -20℃ ~ 60℃ 存储温度: -40℃ ~ 85℃ |
电源输入 Power Input | 9-36V DC |
尺寸 Dimensions | 3.5" (146 x 105mm) |
操作系统OS | Windows 7/8/10, Linux |
■ 配置Configuration | |
型号 Model Name | CPU型号 |
CEB-6103-W100 | I3-6100U |
CEB-6203-W100 | I5-6200U |
CEB-6503-W100 | I7-6500U |
■ 订购清单 | ||
类型 | 型号 Model Name | 描述 |
标配 | CEA-PW12-CAB0 | 1xDC in, 1x4P, 120mm |
选配 | CEA-6203-FAN0 | Skylake-U CPU Fan module |
CEA-CM15-CAB9 | 1 x COM, 2 x 5P,150mm, blue | |
CEA-US20-CAB9 | 2 x USB, 2 x 5P, 200mm,black | |
CEA-SA15-CAB0 | 1 x SATA, 7+4P, 150mm, w/o lock, 90°/90° | |
CEA-RM03-CAB0 | 1 x Phoenix conn(5.00), 30mm, female | |
CEA-3COM-1F2N | I/O expansion card,3 x COM | |
CEA-2LAN-GBE0 | I/O expansion card,2 x LAN(Intel 211AT) | |
CEA-1PCI-PCIE-CEP | Riser card,PCI+PCIe X1 | |
CEA-2PCI-CEP | Riser card,2 x PCI | |
CEA-1PCI-CEP | Riser card,1 x PCI | |
备注:CEA-1PCI-PCIE-CEP PCIe信号与主板M.2 2230共用。 |
桦汉科技产品矩阵再扩大,全新升级的IPC-310工控机满足更多场景应用
新品速递|工业扩展型触摸一体机,实现工业应用的无限可能!
凭实力“出圈”,桦汉科技入选市级示范智能车间!
面对制造业的严重内卷,桦汉科技也能迎难而上!
