施克 WL4-3F3130 PNP输出光电开关上海卓鲲
2012/2/2 16:16:06
0 人气:44
- 数量:11
- 有效期:2021/2/17 0:00:00
SI5010
TEL:13564980210 QQ:2513710752 张小姐 我们会珍惜您的每一次来电!期待与您合作!
SI5002
SI5000
PN7004
PN7002
PN7000
PN5004
PN5003
PN5002
PN5001
O1D100
KD0009
KB0025
IN5225
IIS206
IG5788
IG5526
IG0011
IFS204
IB5063
EVC005
DI0001
PSD02-2301
ADAPT-PB-GE-MLG
ADAPT-PB-GE-MLG
C40S-1203AA300
C40E-1203AG300
WL27-3P2431
WL27-3P2431
WTB4-3P3162
WTB4-3P2162
WTB4-3P2264
WTB4-3P2264
WTB4T-3N1264
WTB4-3P1361
WTB4-3P1361
WTB4-3P1461F20 (no discount) Tetra Pak
WTB4-3P3161
WTB4-3P2161
WTB4-3P2161
WTB4-3P2261
WTB4-3P2261
WTB4-3N1361
型号
E6C-NN5C 2M
BES516-317-G-E5-C-S49
RVI50N-09BK03ATN-01000
NBB5-18GM40-ZO
ML100-8-1000-RT/102/115
O1D100
VPRQF-A3-20MPAS-Y5M
替代型号SZR-MY4-H-N1
C7035A1064
H3BA-N
YSAR2-211
YSAR2-311
YSAR2-322
新型号YSAP12-11
YSSEP323-11RA
KT3W-N1116 含电缆
WL12L-2B530S03
NJ1.5-18GM-N-D-V1
扫描枪LS3578
串口线
JMEH-5/2-1/8-B
WL11G-2B2531
CPE18-M1H-5L-1/4
JU100(GJ-8)
NBB5-18GM50-E0
RL39-54/32/40A/82A/116
UC500-30GM-IUR2-V15
国产电缆M79-3430-13-04
ML5-8-400/32/115
ML5-8-400/32/115
串口线
QS186E
QS18VP6R
QS18VP6LV
BRT-84
M79-3434-17-04
O1D100
9460 10*10
KW8*8
9401 8*8
9250
ML100-55/102/115
ORR50
JU100 (GJ-8)
VTE18-4P8112
IM12-04BPS-ZC1
WL250-S132
WT34-B410
VT307-5G-02
RLK39-54-Z/31/40A/116
ABS103B
ABS53B
SZX-SMF-14H
P2CF-11
GCO-CIIID3 OCR50/51
ML5-8-400/32/115
ML5-8-400/32/115
WL250-N132
WT9-2N130P02
WTB27-3P2411
LA39/LK39-Z/31/40A/116
OBT500-18GM60-E5-V1
NBB2-12GM50-E2-V1
BI5-M18-AD4X
BI5-M18-AD4X
MY2N-J AC22V
WT280-P230
WL9-2N131
WL9-2P430
IF5208
IV5007
PE7006
VPRH-A1-199.9KPA-W-2S(HL)-1U
RHI90N-0NAK1R61N-01024
KFD2-SR2-EX2.W.SM
NBB2-12GM50-E2-V1
NBB2-12GM50-E2
E32-CC200 2M BY OMS
O1D100
EVC004
IQ40-20NPP-KK0
E2E-X2Y1-Z
SW50
9401 8*10
9401 10*10
RVI58N-011AAA66N-01024
NBN8-18GM60-WS
NBB5-18GM40-Z0
NBB5-18GM40-Z0
ED-130U
BTL7-S572-M0750-B-S32
VTE18-4P4212
WL23-2P1130
IM12-O2BPS-ZCK
PGM-1700
PGM-1300
SP-07
O1D100
EVC001
KT8L-N3656
KT8L-N3656
IM30-15BPS-ZC1
ML5-8-400/32/115
M8 4芯电缆
O1D100
EVC001
NJ1.5-8GM-N
E1Z4P2K1
NJ1.5-18GM-N-D-V1
O1D100
EVC004
E2E-X2Y1-Z
WL9-2N131
WL9-2N431
WT9-2N430
IMF18-08BNPVC0S
DOL-1204-G02MN
NBN5-F7-E2
NBB5-18GM40-Z0
FVM58N-011K2R3GN-1213
TVI58N-01NK0R6TN-00100
型号/参数
NBB1.5-8GM50-E2
齐平1.5mm M8螺纹 PNP常开 2米直接出线
NBB2-12GM50-E2
齐平2mm M12螺纹 PNP常开 2米直接出线
NBB2-12GM50-E0
齐平2mm M12螺纹 NPN常开 2米直接出线
NBN4-12GM50-E2
非齐平4mm M12螺纹 PNP常开 2米直接出线
NBN4-12GM50-E0
非齐平4mm M12螺纹 NPN常开 2米直接出线
NBB4-12GM50-E2
NBB4-12GM50-E0
NBB5-18GM50-E2
齐平5mm M18螺纹 PNP常开 2米直接出线
NBB5-18GM50-E0
齐平5mm M18螺纹 NPN常开 2米直接出线
NBB5-18GM60-A2
齐平5mm M18螺纹 PNP常开常闭 2米直接出线
NBB5-18GM40-Z0
齐平5mm M18螺纹 直流两线常开 2米直接出线
NBN8-18GM50-E2
非齐平8mm M18螺纹 PNP常开 2米直接出线
NBN8-18GM50-E0
非齐平8mm M18螺纹 NPN常开 2米直接出线
NBB8-18GM50-E2
NBB8-18GM50-E0
NBN8-18GM40-Z0
非齐平8mm M18螺纹DC两线常开2米直接出线
NBB10-30GM50-E2
齐平10mm M30螺纹 PNP常开 2米直接出线
NBB10-30GM50-E0
齐平10mm M30螺纹 NPN常开 2米直接出线
NBB10-30GM40-Z0
齐平10mm M30螺纹 两线常开 2米直接出线
NBN15-30GM50-E2
非齐平15mm M30螺纹 PNP常开 2米直接出线
NBN15-30GM40-Z0
非齐平15mm M30螺纹 DC两线常开 2米直接出线
NJ1.5-8GM40-E2-V1
齐平1.5mm M8螺纹 PNP常开 M12接插件
NBB1.5-8GM40-E2-V1
NJ2-12GM40-E2-V1
齐平2mm M12螺纹 PNP常开 M12接插件
NJ4-12GM40-E2-V1
非齐平mm M12螺纹 PNP常开 M12接插件
NBB4-12GM50-E2-V1
齐平4mm M12螺纹 PNP常开 M12接插件
NBB5-18GM50-E2-V1
齐平5mm M18螺纹 PNP常开 M12接插件
NBN12-18GM50-E2-V1
非齐平12mm M18螺纹 PNP常开 M12接插件
NEB12-18GM50-E2-V1
NBB10-30GM50-E2-V1
齐平10mm M30螺纹 PNP常开 M12接插件
NBB15-30GM50-E2-V1
齐平15mm M30螺纹 PNP常开 M12接插件
NBB20-L2-E2-V1
齐平20mm 矩形40*40 PNP常开 M12接插件
NBN40-L2-E0-V1
非齐平40mm 矩形40*40 NPN常开 M12接插件
NBN40-L2-E2-V1
非齐平40mm 矩形40*40 PNP常开 M12接插件
NJ15+U1+E2(NBB15-U1-E2)
齐平15mm 矩形40*40 PNP常开 接线端子
NJ15+U1+A2(NBB15-U1-A2)
齐平15mm 矩形40*40 PNP常开/常闭 接线端子
NJ20+U1+E2(NBB20-U1-E2)
非齐平20mm 矩形40*40 PNP常开 接线端子
NJ30+U1+E2(NBN30-U1-E2)
非齐平30mm 矩形40*40 PNP常开 接线端子
NJ40+U1+E2(NBN40-U1-E2)
非齐平40mm 矩形40*40 PNP常开 接线端子
NCB50-FP-E2-P1
齐平50mm 矩形80*80 PNP常开 接线端子
NCB50-FP-A2-P1
齐平50mm 矩形80*80 PNP常开/常闭 接线端子
NCN25-F35-A2-250-V1 耐高温250℃
非齐平25mm 矩形40*40 常开/常闭 M12接插件
MB60-12GM50-E2-V1 磁式传感器
齐平60mm M12螺纹 PNP常开 M12接插件
CJ4-12GM-E 电容式
NCB5-18GM40-NO
齐平5mm M18螺纹 NAMUR两线 2米直接出线
NJ5-11-N-G 电感式 8VDC
非齐平5mm φ11 M14螺纹 NAMUR两线 2米直接出
NCN15-30GM40-NO-V1 电感式 8VDC
非齐平15mm M30螺纹 两线本安 M12接插件
NJ15-30GM-N 电感式 8VDC
非齐平15mm M30螺纹 NAMUR两线 2米直接出线
SJ2-SN 电感式 故障安全型
槽型2mm NAMUR两线 8VDC 2米直接出线
SJ3.5-N 电感式
槽型3.5mm NAMUR两线 8VDC 2米直接出线
NBN8-18GM60-WS 20-230VAC
非齐平8mm M18螺纹 常开 2米直接出线
NBB15-30GM50-WS 20-230VAC
齐平15mm M30螺纹 常开 2米直接出线
NBB15-30GM50-WO 20-230VAC
齐平15mm M30螺纹 常闭 2米直接出线
NJ15+U1+W 20-230VAC
齐平15mm 矩形40*40 常开/常闭 接线端子
NJ20+U1+W 20-230VAC
非齐平20mm 矩形40*40 常开/常闭 接线端子
NJ30+U1+W 20-230VAC
非齐平30mm 矩形40*40 常开/常闭 接线端子
NJ40+U1+W 20-230VAC
非齐平40mm 矩形40*40 常开/常闭 接线端子
NCN50-FP-W-P1
非齐平50mm 矩形80*80 常开/常闭 接线端子
RLK39-54-Z/31/40a/116 带延时(0.1-10S)
反射板7M 矩形64*25*75 24-240UC 接线端子
LA39/LK39-Z/31/40a/116 带延时(0.1-10S)
对射20M 矩形64*25*75 24-240UC 接线端子
V1-G-5M-PUR 四芯直头 5米 聚氨酯
V1-G-2M-PVC 四芯直头 2米 PVC
V1-W-2M-PVC 四芯弯头 2米 PVC
V15-W-2M-PUR 五芯弯头 2米 聚氨酯
V15-G-2M-PVC 五芯直头 2米 PVC
KFD0-CS-1.50
1-channel, 0 ... 20 mA
LFL2-CK-U-PVC3 浮子开关 3米PVC
额定电源 |
12 to 24VDC ±10%(Ripple P-P :Max.10%) |
电流消耗 |
最大40mA |
最大45mA |
使用光源 |
红发光二极管(调制) |
灵敏度 |
2种调节装置(粗调,细调) |
自动调节 |
动作方式 |
通过控制线选择Dark ON 和Light ON方式 |
自动设置Dark ON 和Light ON方式 |
控制输出 |
NPN universal output :-->负载电压:30V,负载电流:最大.200mA,残留电压:最大.1V |
保护电路 |
反极性保护,短路保护 |
指示灯 |
动作指示:红色LED |
STAB:目标物在稳定的探测区内时绿色指示灯点亮,输出时:红色灯亮 |
连接 |
电缆连接 |
绝缘电阻 |
20MΩ Min ( 500VDC ) |
抗干扰 |
power line ±240V at pulse band 1us of noise simulation |
耐电压 |
1000VAC 50/60Hz 一分钟 |
抗振动 |
10 to 55Hz (周期每分鐘 )复振幅1.5mm X、Y、Z各方向2小時 |
抗冲击 |
500M/S2( 50G ) X、Y、Z各方向3次 |
环境照度 |
太阳光:11,000 Lux.Max.,日光灯:3,000 Lux. Max. |
环境温度 |
使用时 : -10 to +60℃( 未結冰狀態下 ) 储存时 : -25 to +70℃ (未結冰狀態下 ) |
环境湿度 |
使用時 : 35 to 85% RH 存储時 : 35 to 85% RH |
材料 |
外壳:ABS, |
外壳: |
电缆 |
4P, Φ 5mm,长度:2m |
额定电源 |
电流消耗 |
最大40mA |
最大45mA |
使用光源 |
红发光二极管(调制) |
灵敏度 |
2种调节装置(粗调,细调) |
自动调节 |
动作方式 |
控制输出 |
保护电路 |
反极性保护,短路保护 |
指示灯 |
动作指示:红色LED |
连接 |
电缆连接 |
绝缘电阻 |
抗干扰 |
耐电压 |
抗振动 |
抗冲击 |
环境照度 |
环境温度 |
环境湿度 |
材料 |
外壳:ABS, |
外壳: |
电缆 |
4P, Φ 5mm,长度:2m |
- 电话:021-61558436
- 传真:021-57626318
- email:zkzhang10@163.com
工控宝APP下载安装
