- 型号:VMIC VMIVME-6015
- 数量:10
- 制造商: 厦门兴锐达自动化设备有限公司
= 0.215 0.00304 = 0.218 Nm
X轴制动转矩:Tsx = (JLX Jm7)●a - TL
=0.441-0.035=0.406Nm
Y轴制动转矩:Tsy = (JLY Jm4)●a - TL
= 0.215 - 0.00304 = 0.212 Nm
通过以上的计算选用的是松下MHMD400w和MSMD750w的交流伺服电机,该型号输出惯量
适合,运行更平稳。X轴用的是750w的伺服系统,额定扭矩为2.4Nm;而Y轴用400w的伺
服系统,额定扭矩为1.3Nm;这两款的额定转速都为3000rps;所选伺服的惯量及扭矩都能使载体平稳的运行。
(3)盘式电机选型
由于在盘式伺服上要放的是一个铝制的圆盘,圆盘规格(R=150mm M=1kg 实心):
圆盘惯量J=1/2?M?(D/2)?=1/2?1?(150/2)?=0.0028125 kgm2
扭矩T=角加速度a?惯量J
圆盘转π/2需要的时间是4s,平均角速度V=π/2?4=0.3925rad/s
则:角加速度=角速度V/加速时间t=0.3925?0.01=39.25rad/s?
则:扭矩T=39.25?0.0028125=0.1104Nm
由于惯量要匹配,盘式伺服承受物体的惯量和盘式伺服自身的惯量的比例在1:10之内是最理 想的,所以所选的盘式伺服ND110-50F自身的惯量是0.00034 kgm2、额定扭矩是2.4Nm最大扭矩是7.2Nm、回转速度是5rps、分辨率是720000 ppr。该盘式伺服的定位精度是±90s,重复定位精度是±18s,外加绝对值选项定位精度可达±15s、重复定位精度±1.8s。360度=1296000s,圆盘周长 L=πR=3.14?150=471000um,则角度1s=0.363um弧长,所以当定位精度为15s时圆盘的弧长精度可达到5.445um。
1.1实现功能
1、原点复归
2、激光功率检测
3、芯片切割
1.2系统设计
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
GE FANUC VMIVME-7700-110000 VMOD-C6
GE FANUC VMIVME system controller
VMIC VMIVME5588 VMIVME DMA High-Speed Reflective MVME
GE Fanuc VMIVME-5576-000/VMIVME-5576/VMIVME5576/5576
VMIC 4941 VME Board VMIVME-4941
VMIC VMIVME-5530S Fiber Optic Slave VMI VMEbus VME5530S
VMI VMIVME 7487A MAINFRAME BOARD
VMIC GE Fanuc VMIVME-3114 VMIVME3114
GE FANUC VMIVME-1182 VMIVME 1182 VMIC VMEBUS VMIVME1182
VMIC 1111 VME Board VMIVME-1111
VMIC / GE Fanuc VMIVME-REPEAT L-485 Long-Line VMEbus
VMIC VMIVME-6015 5-CH Multifunction Input/Output Board
VMIC VMIVME-7592 Single-Slot Pentium / AMD-K6 Processor
VMIC VMIVME7452 NSPP VMIVME7452
VMIC VMIVME-6015 Multifunction
VMIVME 7487A CPU BD. Opal 70512526000
VMIC VMIVME-7589 VMIVME7589 VMEbus VME MAINFRAME
VMIC CPU Board VMIVME3112 #10600
VMIC VMIVME-3115 12-Bit High-Throughput Analog Input
GE Fanuc VMIC VMIVME-7486 PC/AT VMEbus CPU ___H156
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
