- 型号:Allen-Bradley 1336S-BRF75-AE-EN4-HA2
- 数量:10
- 制造商: 厦门兴锐达自动化设备有限公司
Proco Products Series 442-BD PTFE Expansion Joint 1-1/4"
Allen Bradley 1746-0W8 Ser. A Output Module
Adtech Spirent SX/13 Data Channel Simulator w/ T1
Perceptron TriCam Digital 2 515-0093
Pepperl & Fuchs NBB20-L3M-US-C3-V93 Inductive Sensor
DFI 750-EC8000-151G EC800-CD2041-GIL Fanless Embedded PC System
Allen-Bradley SP-135111 SCR Module 55A 1200V NEW
Mitsubishi A1SD62D High Speed Counting Unit A1S-D62D
Westinghouse 2D78548G03 IQ Central Energy Display w/ PONI Module & Sentinel
Fanuc 5F/3000 A06B-0345-B231 Servo Motor New in factory box
Rosemount 8707AVA060C1W0N0L1 Magnetic Flowtube
BD Sensors DX19-DMP 331 111-P020-E-3-100-200-2-000
Horton Automatics C7220-1 Rev B C07220.0001 Interface Module
Phoenix Contact 2903231 ST-OV3- 24DC/240AC/3 NEW
Allen Bradley 1756-M12 Rev A 96395674 ControlLogix Expansion Memory Rev G 02
Longfellow LFS-2/300-EA5 Linear Motion Position Transducer Linear 15" Waters Mfg
Mcdougal Littell Mathematics Course 1 Larson Boswell Math book middle school
Weldon 3" Crest-Kut End Mill Bit B-10263 9" Long
Lucent 408764173 T-CD-B2/B MODCELL Filter Assembly B2/B
Maska XTB35X3-7/16 TX Bushing w/ Hardware NIB
Badger Meter RCDL 5/8" Flow Meter 63324-014
Ultratec CLF-4145 120V Fluid Distribution System Pump for Fog Effects
Perceptron 917-3008 Rev 1 S0400-X0075-Y0102-Z0215 Digital Surface Sensor
Graco 224437 Repair Kit for LSBPR
Perceptron TriCam Digital 2 515-0097 H 4967
Lutron Hi-Lume H3DT825CU110 Programmed Rapid Start 1% Dimming Ballast
TPM DPD-4X 4 Mil. Xerographic Film 24X50 YD
Toyoda/Toyopuc TXU-2837 64URT2 I/O PLC Unit
Marposs 3415420509 Head Gauge? Transducer Gauge? New
Stanley A30LATA-20 3/8" Pneumatic Angle Nutrunner 1875 RPM
Danaher Controls Dynapar HC6255000024D 3/8 SHT FLG MT 5-26V SD MT
Shindengen SY02120G Power Supply
ADC D1M-1X0019 DS1 Panel 30 Terminal FX Block 8" x 5.5"
Wabco S-1 Load Sensor Portion 0577644-0200 0577644
Controlotron 994-4A CPU Module 994-4A-1
GE Fanuc 44A398711-G02 PC Board for 1050 CNC Control
Regal-Beloit T358 Variable Speed AC Drive
Fisher Rosemount DM6461X1-A3 Discrete Output Card
ADC NGF-ACCIS0P30X24 30 x 24 in. Isolation Pad NEW
ELODRIVE BN-176P1U Electric Actuator 24V
Omron C200H-IDS01-V1 Programmable Control
Mitsubishi Melsec AJ65SBTC1-32DT Input/Output Unit
McGill SB 22204 C3 W33 SS Bearing SB22204C3W33SS
Hakko V4T050J-B Operator Interface Programmable Panel
Abnormal Psychology: An Integrative Approach 6th Ed. Barlow Durand w Access Card
Sick Optic Electronic CLV432-6010 Barcode Scanner w Clamp 1 017 983
Mitsubishi Net / II Master / LocalFiber Link A1S-J71AP21 A1SJ71AP21
Carlisle Gold Ribbon Cog/belt - Band 3 Ribs RBX95-3
IFM Electric Efector 200 OYA0610-14-4-06-P-1 Photoelectric Sensors
NuTech 20CX1 0306 Quick Exhaust Relay
Valbart K1A8XA8AFWL0X062N104 Trunnion Mount Ball Valve
Electronic Systems Inc. 4IA B-77042 Isolation Amplifier ESI
Entrisphere 220-0002-01 D3a-6 Pack D3a Ds3c ATM sealed
安森美助力工业生产视频监控
安森美半导体作为领先的图像传感器供应商,产品用于安防还用于相近市场,保持广泛基础的先进技术,可被充分利用发挥,横跨用于各类应用。在工业生产现场,通过视频监控系统就能够快速、实时的进行监控和监视。
事实上,监控/安防市场未来几年会持续稳步增长,尤其是随着图像信号处理压缩标准如H.264和H.265成为主导。这使更高分辨率、更快帧频视频的传输能用于视频分析如面部识别。
安森美半导体图像传感器部安防细分市场营销经理BrianBenamati表示,网络摄像机是未来视频监控业发展的重点,而对它不断地创新与发展有赖于关键元器件图像传感器的性能。
Brian进一步指出,对于在监控上采用的图像传感器在技术上的要求,监控/安防市场的摄像机制造商和系统集成商有两大关键性能要求:卓越的微光成像(在微光场景条件下提供足够的信噪比)和高动态范围(HDR,以同时捕获在明亮高光和暗阴影下的成像)。一旦实现这些关键参数,接下来的性能因素包括扩展的近红外(NIR)量子效率(用于以NIR照明器成像),和出色的调制传递函数(MTF)(用于图像清晰度)。
Molex紧抓工业连接器发展机遇
Molex中国销售经理JuiGoyEng认为,工业连接器确实在IoT、智能工业浪潮下面临了很大的机遇,主要表现在以下三方面:
第一,无线连接对于智能产业具有极为重要的作用,通过在无线网状网络上部署具有移动、微型化和网络化的各种“智能”设备,可以实现最优的生产效率。比如说,Molex在此供应一系列标准天线,特别适用于上述应用。
第二,智能工业流程的优化还将推动众多应用在人机接口(HMI)中的效率,而Molex提供包含液位传感器在内的各种电容式触摸传感器产品。
第三,光纤互连系统也是推动智能产业的成长以及物联网(IoT)长期演进的主要因素。Molex开发的圆形透镜MT扩展束互连解决方案,能满足数据密集型行业的特定要求。
高集成度也是应对工业4.0时代的必备条件,比如越来越多的半导体供应商开始将MCU与传感器加以整合。在工业自动控制系统中,传感器当处系统之首。类似于感官系统的传感器能快速、精确地获取信息并经受严酷环境的考验,是自动控制系统达到高水平的保证。可以说,没有众多质优价廉的工业传感器,就没有现代化工业的生产体系,更别谈工业4.0体系的构建。此外,具有低能耗、低成本、易使用和泛在感知等特性的无线传感器网络正在快速崛起,使传统实践中因成本等因素未能实现在线检测的某些重要工业过程参数的测量成为可能。
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
Triax TMS 9x12p Power Supply 300342
Hubbell HBL20418 3-Pole 4-Wire Flanged Inlet
ServiceFirst VAL02980 Emerson ANE 5 HCA Thermal Exp. Valve X15110480110
Lexmark 11K4647 Optra S Kiosk Presenter Adapter
King Instrument 7510212A-02 Acrylic Flowmeter 1/4" Port 7GPH
Cooper DSD948 J3 Explosionproof Cover Assy Pilot Light green
Neugart PL70N Gear w/ Bosch SG-Y1 AC Servo Motor
NSK ESA-LYB2T15-11 Servo Drive YB2514-492 180-242V 50-60Hz
Dataradio TX 700 MHz T881-10-8200 Radio Transmitter
SMC EX230-SDN1 VV816-03S-SUQW0 4BT-W1 Pneumatic Valve Manifold
Invensys VM2223 2 Way Valve Body
Stanley CAN8R 3/8" Pneumatic Nutrunner 7405 A-4031 ?
Sloan MCR139A Solenoid Lavatory/Shower w/ 15' Cord NEW
ANSI Grade 1 Reversible Exit Device EX100081 U-613 8630F/8830F SVR Type US3 Gold
Sick Optic Electronic C2000 C20S-120103A11 1016594 Type 2 Sender Light Curtain
Siemens 5SY41 Supplementary Protector 5SY4116-7 MCB C16
Sick Optic Electronic KT5-P1211 Contrast Sensor
GCA Corporation LR-420 Probe Force Kit w/ Case
BS&B JRS Reverse Buckling Rupture Disk 1-1/2" A4080148-1
Gates 9388-4132 4/3VX1320 Super HC Powerband Belt 132"
Schneider Electric Phaseo ABL8 RPS24100 Power Supply
Delta Tau Data Systems ACC8D-OPT2 Dual Axis Interface Board 602234-101
Stanley A30LATA-30F3 3/8" Right Angle Nutrunner 2200 RPM
Cleveland Motion Control S3002M000007 Micro Servo Drive
Gleason Cutting Tools 58268-000-5 Cylindrical Workholding Chuck 5011600-000-08
United Electric J120-185 Pressure Switch 3/4" 15AMP
Mitsubishi Super Line .75 Kw 2 Pole AF-SERV Induction Motor
Cleveland Motion Controls S128780 Incremental Encoder
Sick Optic Electronic Type 2 Sender LGTS075-291
Mitsubishi Melsec A1S-TA32 32 Point IDC Wiring Adapter 20AWG
iSys Media iTerra Lite Standard Top Coat IJ-SCFF1000
Yaskawa JANCD-XI002 Rev. B PC Board Add-On JANCD-XI0O2
Banner SI-QM100AMMG 46716 Safety Lock w Box
联系人:刘锦燕
手机:13295922579
电话:0592-5580706
传真:0592-5361191
邮箱:LJY_05228@163.COM
QQ:2711934024
QQ:2574619415
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
工控宝APP下载安装
