- 型号:Oilgear L407508-001
- 数量:10
- 制造商: 厦门兴锐达自动化设备有限公司
Square D 8502-SB02-V02 Form S Series A Contactor NEMA Size 0
Browning NSS12H36 36-Teeth Spur Gear
ALTRU-V V-Mod 24" 120V-S/S Modular Coil Irradiator
GE Electric Motor 5KC19SG76 1/2 HP 2850 RPM GE5KC19SG76 Code F
Seco CD-03 3HP AC Drive CDME 03 Variable Frequency Inverter
Telemecanique ZB2-BE102 Contact Block ?
Controlotron 991PMS-2 Transducer V/M A2 991PMS2
CPV O-Seal Valves 1/4" Gage Root PSSSN21C-505 EBPN 11401-B11-DNF
Danfoss 084G2113 Pressure Transmitter EMP2 80 Bar
Crouzet 83777371 LA Plaine 12 Electrical Industrial 54" 6-Wire Sensor
Controlotron 994-4ADP3-3 System Computer 994-4A
Siemens I-T-E Sentron Series SMD69600A SMD6 Type 3 Pole Circuit Breaker
Qty of 1000 Standard Motor 217512-000 OP AL Heater for O2 Sensor 100050
Micro-Trak Orion 18450 MM13 ElectroMagnetic Flowmeter Kit MPS-S/P/G
Siemens 34BF33AFAAF Starter 2 Speed Contactor Controller 3P X13070094040
WPS World Power Systems 2-1946-BO 12V
Honeywell JEC 060-H033-01 Long Stroke Linear Transducer
CTC Parker Automation Touch Screen Control Panel P51-314-B1-2A3
Siemens Sirius 3R 3RV1011-1DA20 Starter Motor Protector
Fireye NX04-1 Servo Motor 50/60hz
Allen Bradley 1336S-B007-AN-EN3 AC Drive
Nissan 29359-L4000 Controller Cover
Mitsubishi Meslec AJ71C21-S1 Serial Communication Module
IEC SPJP Plug Connector International Electric Co. SPJP3485 30 Amp 3W 4P
Mitsubishi Melsec AJ65SBTB1-32DT1 Outfast Switch
Moore Servo Control Board Assembly 15823-1
Devar Inc. 18-119 High-Level Isolated Transmitter w Manual
Siemens 3RK1300-0BS10-1AA0 Starter EM 300 ERS
Allen-Bradley DataLiner 2706-LV2S Ser. A Rev. B Operator Interface
S&C Electric Company SMU-20 27kv Max K Speed 703020 Fuse Unit
Victaulic S381PCQ410 V3802 Concealed Quick Response Automatic Sprinkler FireLock
Advanced Hardware Technologies AHT-9 S4CL Concealed Vert. Rod & Rim Exit Device
Kone ADON2 G01 LCEADON PCB Assembly Board KM93567G01
T.A. Systems #EL-9060 Sonic Relay EL-9060
Fairchild TD7800-014 Electro Pneumatic Transducer NEW
Thomas & Betts 8003U-1 Ever-lok Receptacle
Stanley F33L147ACT-4 Nutrunner
Quantum XP31070W AT10W011-08-H-C Rev B FS054593-0201
Pall Trinity Micro ML0X 03-30-1/4GS-MM 2221996 M499610 Gaskleen Filter Assembly
Rexnord Thomas 350.S71.CMBRA C=7.00 7204 Stainless Steel Disc Coupling
Flex-Cable FC-XXFEFMP-S-E015 15' Encoder Cable
Spear System STT-13DBXF2-122 D122VXMF01382T Welding Tip
Chemetics Aker 78358 Main PCB for Anotrol IV Controller
Foxboro ID10-TSAC01F-M1 Differential Pressure Transmitter 700C-1152N Diaphragms
Woodhead 4022 Pendant Safeway 2Button Station
Nissan 44060-30K25 Brake Pad Shoe Set (4)
GE Fanuc 44A735538G11 Upgrade Kit V8.21 CPU323
Siemens 3RG7651-0AB00 PXO220 Sensor Opto-BERO M18
Tokyo Keiso P-500-1LPA Purgemeter Flow Meter
Baldor KPD-TS03M-10 HMI Touchscreen Panel
Oilgear L407508-001
OFweek工控网讯:中国今年推出了“中国制造2025”计划及详细实施方案,协助中国制造业加速工业自动化发展,引爆庞大智能自动化与机器人的巨大商机。同样,工业4.0带来的技术发展势必让半导体大厂在企业架构上做出一系列新调整,以适应新的市场形势。
德州仪器的电机驱动方案四大攻势
德州仪器模拟产品业务发展经理信本伟指出,电机是工业领域非常重要的一部分,同时也被称为耗电大户,如何利用好电机,一直以来都是业内非常重视的问题。信本伟先生认为,对算法的优化其实很大程度上也是聚焦在对效率的优化上,在此领域一直居于业内领先地位。TI的产品通常会选择最优驱动端的MOS,对于小电流的电机驱动产品TI通常集成MOSFET并且优化RDSON,同时也持续通过降低静态电流来减小电机不运转时的功耗。
作为全球市场领导者,TI利用先进的电机控制专业技术方面的丰富经验,并结合模拟和嵌入式处理产品系列,可提供完整的电机系统解决方案。总结起来TI电机驱动产品和方案主要有四方面的优势:
1、产品覆盖面广。我们的产品可以用来驱动直流有刷、无刷、步进电机,针对伺服电机也有解决方案。在每个细分的电机类型里,我们也有不同的解决方案,比如针对时下最热的BLDC,我们有有感、无感的解决方案,也有方波控制、弦波控制和更复杂的FOC,针对不同功率的电机都可以找出相应的解决方案。
2、易于使用,可以缩短客户的研发周期。我们的DRV8系列有刷以及步进电机驱动,和DRV10($0.4387)系列的无刷电机驱动芯片,都是将控制部分集成在电机内部且性能很高,客户可以很容易就完成电机驱动端的设计,从而将更多的精力投入到系统端的研发当中。
3、可靠性高。TI的电机驱动方案将保护机制集成在芯片内部,可靠性很强。同时TI的算法也是致力于可以驱动有不同参数的电机,使同一款产品可以应在有不同应用需求的终端产品中而不产生问题,简化研发周期。
4、完备的产品和支持。TI的产品不仅仅是芯片本身,我们还提供配套的评估套件、参考设计、应用手册等等,方便用户使用。当客户有问题时可以联络我们的FAE,但更方便的是直接登录我们的E2E论坛或者为德州仪器在线支持社区,我们的电机驱动专家会在论坛上直接帮客户解决技术问题。
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
Oilgear L407508-001
Oilgear L407508-001
联系人:刘锦燕
手机:13295922579
电话:0592-5580706
传真:0592-5361191
邮箱:LJY_05228@163.COM
QQ:2711934024
QQ:2574619415
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
工控宝APP下载安装
