- 型号:Lam Research 810-017031-004
- 数量:10
- 制造商: 厦门兴锐达自动化设备有限公司
Lam Research 810-017031-004 ADIO A0 PCB Card Rev. 01 810-17031
Lam Research 810-017031-004 ADIO A0 PCB Card Rev. 1 810-17031-4
Orion Machinery ETC902-NSC-LP Heat Exchanger Pel Thermo As-Is
Nikon 4S065-417 Power Supply Assembly With 4S065-418 Interface
LAM Research 853-017160-583-B-LEAN Rear EMO Assembly PCB 810-017003-004
LAM 4420 Solenoid Tray Assembly Missing PCB 853-013610-501-A-LEAN
LAM Research 4420 Solenoid Tray Assembly 853-013610-001-D-C222
LAM 4420 Solenoid Tray Assembly Missing PCB 853-013610-001-E-LEAN
LAM 4420 Solenoid Tray Assembly Missing PCB 853-013610-001-D
LAM 4420 Solenoid Tray Assembly Missing PCB 853-013610-001-E-4050
Lam Research 810-17016-1 Stepper Motor Driver Rev. B Rainbow 4420 Lot of 7
Lam Research 810-17031-2 ADIO A0 PCB Rev. 2 Rainbow 4420
Lam Research 810-17031-4 ADIO A0 PCB Rev. 2 Rainbow 4420
Nikon NSR S307E AD-LSO1 Board 4S019-238
Parker SX6-DRIVE Indexer Drive Compumotor
Crown Yutaka Eng. Corp. ERSB-3019-WX Regulator Valve lot of 8
Nikon NSR-S306C 4S018-866 PPD3X4 PCB
AMAT Applied Materials 0041-24879 ALD TAN Lid Cap 300mm new
VAT Angle Valve 26324-KA11-1001 62034-KA18-1005 26328-KA11-1002 Lot of 7
Applied Materials AMAT Vacuum Roughing Line Matrix Kit 0227-05061 New
AMAT Applied Materials 0242-70282 300mm Vacuum Roughing Line Kit new
Lam 4420 Shuttle Assembly 853-012550-001-H
Lam Research 853-012550-001-D Wafer Shuttle Assembly
Lam 4420 ADIO-AO PCB 810-17031-3 Rev. I
Xycom 70113-001H Memory Board Lam 4420
ASML Nikon Reticle CCM Remote Control Box 4022.470.0889
ASML Nikon Reticle ROB Remote Control Box 4022.470.0883
Omron Z4LC-C28 Parallel Beam Line Sensor
Dolan-Jenner A2416TC42 Illuminator System A-241P A-241L KLA-Tencor AIT2
TEL Tokyo Electron 1D81-000098-B4 DIO Control Card TYB112-1/DIO
TEL Tokyo Electron SHU Shuttle Slider Assembly ACT 12 300mm
SVG 90S Multiple Sensor Motherboard 99-80271-01
ASML DSX Stepper A1 Prime 8540138001
Nikon 4S007-953-A NSR Series PCB WL3MOT5
Nikon 4S018-567-A NSR Series PCB WLS3EN4
OFweek工控网讯:透明市场研究(TMR)最近公布的报告预测,在2014年到2020年期间,全球工业机器人市场年复合增长率将达6.2%。TMR是一家美国的市场情报公司,指出,全球工业机器人市场的市值将从2013年的289.3亿美元不断增长到2020年的444.8亿美元。标题为“工业机器人市场--全球产业分析、规模、份额、成长、趋势和预测,2014-2020”的报道即将在网站发售。据该市场研究报告,中小型企业广泛采用机器人技术和劳动力成本上升等因素推动了全球工业机器人市场的发展。高投入的研发活动和关税减少,特别是在亚太地区和世界其他区域,都将成为推动整个工业机器人市场的另一个主要因素。更多地在制造业和战略性业务扩张计划中使用机器人技术在预测期内将会为全球工业机器人市场创建几个增长机遇。
TMR报告将全球工业机器人的市场根据类型、行业、职能和地理进行了细分。根据类型划分,这个市场被划分为圆筒形机器人、水平多关节机器人(SCARA)、直角坐标机器人和关节机器人。根据行业划分,全球工业机器人市场可被分割成精密和光学、食品饮料、金属、机械、橡胶、化工、塑料、电器及电子产品、以及汽车。其中,精密和光学、金属、食品和饮料是在今后几年,主导工业机器人总需求的三大行业。根据功能划分,该报告将全球工业机器人市场划分成铣削、切削加工、绘画和分配、组装及拆卸,材料处理,锡焊和焊接等。
在2013年,材料处理行业占据全球市场最大的份额。
从区域划分的角度来看,该报告将全球工业机器人市场分类为亚太地区、欧洲、北美和世界其他地区。在收入方面,2013年全球工业机器人市场由亚太地区主导。亚太工业机器人市场的增长可以归因于其广泛的研发活动,如印度,中国,澳大利亚和日本。可以预料,亚太地区对工业机器人的很多需求将来自中小企业,在今后几年,机器人将出现大规模应用。在北美,墨西哥有望成为工业机器人一个具有发展潜力的市场。(Tina译)
进入首页浏览更多精彩内容:
OFweek工控网讯:2015年8月19日--艾默生过程管理公司对向中国四川省提供清洁电力的射洪县柳树水电项目实行自动化。
水电开发,特别是小水电,作为一种清洁能源在中国越来越受欢迎,可补充火电并为农村地区提供电力。此项目是由沱牌电力开发有限责任公司建设,包括三个16兆瓦机组,以帮助满足四川西南射洪地区日益增长的能源需求。第一台机组预计将于2016年三月投入运行。
艾默生将提供Ovation控制和SCADA技术以管理水力发电业务。“沱牌电力开发”是在中国首个采用分布式控制系统技术的水电发电机,提供更严格的总量控制,增强诊断功能,提高工厂效率,提供可靠的电网同步,提高网络安全和确保更高效的运营商部署。
“艾默生和Ovation技术的良好声誉主要影响了我们的决定,”四川沱牌电力开发有限公司的仪表和控制经理李祥林说。“我们对艾默生在全球水电组件方面应用控制和SCADA技术的经验印象特别深刻。”
Ovation技术将直接控制主厂房的设备和工艺,进行自动调压,并管理24个泄洪道的信息。艾默生还将提供其罗斯蒙特压力和液位变送器。
“在近20年里,我们在成功的化石燃料基础之上开发替代能源的自动化战略,”艾默生过程管理的电力和水处理解决方案的总裁鲍勃·耶格尔说,“我们的行业和自动化专家期待与四川沱牌电力开发合作,因为他们为这个地区创造了清洁,高效的水电。”(Tina 译)
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
AMAT Endura Shutter Disk 0020-29157 new
PULNiX TM-710i High Resolution Monochrome CCD Camera
Lambda LRS 52M-5 DC Regulated Power Supply Reseller Lot of 5
TEL Tokyo Electron 3D10-250834-V1 CEL Process Plate
NANOmetrics 7300-013555 CE-Chuck Full Contact AMAT 3820-00003
Varian E11292270 Analog Digital I/O Interface Rev. G
AMAT Applied Materials 0041-12192 Reflector Plate
Parker CPHX-DRIVE Indexer Driver Compumotor Plus
AMAT Applied Materials 0100-35053 Mainframe Interlocks PCB Card
SCP Global Technologies 00033602-00 MCS-E PIM Interface
TEL Tokyo Electron 300mm Wafer Shuttle IRAM Interface Block Lithius
Kensington Laboratories 4000-6010-02 Single Board Computer PCB SB240012
Bird 8726 Termaline Coaxial Load Resistor 5000 Watts Novellus 27-028428-00 New
TEL Tokyo Electron 3D05-300142-V3 Insulator ESC Enclosure COC New
TEL Tokyo Electron 3D05-300067-V1 Insulator ESC Enclosure T3.5 New
AMAT Applied Materials VAL-001-1482-01 CHAMBER COMMON INTLK AMAT 0100-01108
TEL Tokyo Electron CPC-G222C01A-12 CSB PCB Add On Board TKB2142
Yasunaga YP-20V Air Purge Pump 2985-511354-12 TEL ACT12
Nikon 4S018-379-SPI0X2 Scanner PCB Card
TDK 4S001-102 Power Supply Assembly Nikon NSR-S307E
Nikon Z-4B1A-A1901 Power Supply Module NSR-S307E
Edwards NRYOTN100 Pump Rack Control Box 2xiGX100L/2xiGX1OOM
Particle Measuring Systems FiberVac II Control Power Supply As-Is
Anelva 233405043 Pneumatic Angle Valve KF80
Nikon 4S018-765 IU-DRV4 Driver PCB NSR
Nikon NSR 4S019-080 IU-PWR2-X4P2 Power Board
Nikon NSR 4S018-923 IU-PWR1-X4P Power Relay PCB
联系人:刘锦燕
手机:13295922579
电话:0592-5580706
传真:0592-5361191
邮箱:LJY_05228@163.COM
QQ:2711934024
QQ:2574619415
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
上一篇:Leica S4E
工控宝APP下载安装
