- 型号:Sony C6X17
- 数量:10
- 制造商: 厦门兴锐达自动化设备有限公司
Anorad 73777 Brushless Servo Amplifier SMA8415-1C54-003-1A-1-01
SMC AMR3000-02S Pneumatic Manifold Panasonic LSC BP225-MJ
GCA 66635-14 Circulating System Tegal Precision Scientific Not As-Is
Haake 002-9802 C35 Circurlator Bath F6 002-9513 Not As-Is
Edwards C5168 High Vacuum Adapter Tube Tee ISO160 to ISO100 NW25
Mitutoyo 378-802-2 Microscope Objective M Plan Apo 5 0.14 ∞/0 f=200
Navitar 1-6232 Microscope Body Tube 6.5x Zoom
LiCONiC 91 21 00 92 Stepper Board Lift TP/Nu PCB NMC 1.6.7 Brooks
LiCONiC 91 21 00 92 SMC Stepper Board Lift TP/Nu PCB NMC 1.8.0 Brooks
WEG GG24765 Pump Motor New
Haug Biel AG HB-0521 Static Line Charge Eliminator Control EN SL RLC New
Schunk 360152 Rotary Press Actuator Motor
Burkert DA2.S Flow Switch Actuator
Grundfos 80B2-19FT100-C Pump Motor 85165105 MG Series
Woods Air Movement GE724310 Pump Motor HE724310
Grundfos 49Z51695-P1-0406 Pump Flow Control Assembly TP 32-260/2 A-F-A-RUUE
SMC 0010-26749 Gate Valve Actuator 300mm Rev. 002 Copper Exposed
Okaya 3SUP-H100H-ER-4 Noise Filter Lot of 2
Hitachi RYX-2 PCB M-511E
Hitachi BBS511-1 15-Port PCB M-511E
Hitachi PTPA-01 PCB M-511E Lot of 2
Hitachi BBS210-2 12-Port PCB M-511E Lot of 2
Yaskawa CIMR-J7AA21P5 Drive Controller VS Mini J7 Lot of 2
Artesyn 494000711 2-Slot CBVVI VME PCB
View Engineering 2860240-511 DCO/MCU PCB Board
View Engineering 2860070-519 DSP/Combiner PCB Board
ASML Image Sensor Board 4022.437.0576
Hitachi DT-01 PCB Board Rev. A Hitachi M-712E Dry Etcher
Fuji Electric 50 100 A Circuit Breaker Lot BU-ESB3050 BU-ESB3100
Siemens ED43B015 Circuit Breaker Lot 15amp 480VAC
SMC Thermo-Con High Lift Type Module INR-244-220A
Sony C6X17
View Engineering 2109385-511 Controller Assembly GA-365-1 2109380-507
KLA-Tencor 547220 AIT2 Keyboard Breakout Interface PCB Rev. AA
Airpot Actuator S160P 455 X 550 KLA-Tencor CRS-ABI 2000
Hitachi CWS15 CWS150 AGP Video Card
Contec PI0-32/32L 9859A Interface PCB Board
ASM 858-8163-002A PCB Board
Therma-Wave Frame Breakout Board 14-018238 Rev. C Opti-Probe
DISCO D3 PMCB EAUA UA-266105 Interface PCB Board
Therma-Wave 14-018274 INTFC OPT PL TALL PCB Opti-Probe
SVG Perkin-Elmer A/D Position Regulator Conversion Board 851-8518-004E
SVG ASML A/D Position Regulator Conversion Board 851-8518-005C
Sony C6X17
产品名称: 噪声在线监测/取证系统
产品型号: ENS系列
基本参数: 无人值守,实时监控
产品介绍:
功能特点
全天候自动监测:防水、防尘、耐高/低温,24小时X365天不停机运行
定时监控:每天或每小时定时采集,采集时间和间隔可灵活设置
噪声限值监控:记录超过法定限值的噪声,不同时间段可设置不同的限值
可同时采集噪声分贝数值和现场高保真背景音频信号
可通过设置报警条件进行噪声事件管理
通过公网传输数据,组网容易,运营成本低
多重容错设计、性能稳定,硬件看门狗技术、永不死机
便携式轻便、小巧,便于携带和现场安装
灵活的数据查询和统计方式,支持噪声音频曲线回放
可集成GIS功能
性能规格
低功耗位嵌入式芯片(300MHZ),64M SDRAM(最大256M
2个标准端口,1个RS-485/422可选端口,4个USB口
10/100M 以太网控制RJ-45接口,1个并行口
高精度毫秒级实时时钟,支持掉电保护及看门狗功能
支持AC97音频接口,麦克风输入、线路输入/输出
工作环境:温度 -10℃~+60℃,湿度 5~90%,不结露
电源供电: DC 5V/1.2A(典型值)
参考的环境噪声标准
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
SVG Perkin-Elmer A/D Position Regulator Conversion Board 851-8518-004F
SVG Perkin-Elmer A/D Position Regulator Conversion Board 851-8518-004K
Texas Instruments TM900/203A- Interface Board 115678002 Rev. B
Cymer ADC Interface Board 05-05184-00 Rev. 011
Cymer Interface Board 05-05182-00
Cymer ADC Interface Board 05-05184-00 Rev. 001
Schlumberger TLA DC Motor Driver Assembly 504-000
Nikon KXG72147 Power Supply 4S007-854-1 NSR S204B
Matrix Transport Interface Board 1010-0019 Rev. A
Matrix Transport Interface Board 1010-0019 Rev. B
BTU Engineering System I/O Board 3161161 Rev. 7/14
BTU Engineering Video Interface Board 3161524 EPROM V2.3
Sony C6X17
BTU Engineering Video Interface Board 3161524 EPROM V1.1
BTU Engineering Video Interface Board 3161524 EPROM V2.1
BTU Engineering Video Interface Board 3181180 EPROM V2.1
TEL Tokyo Electron 3281-000085-11 PCB Pincette Base 3208-000085-11 P-8
TEL Tokyo Electron 3281-000148-13 PCB LST-2 3208-000148-11 P-8
KLA-Tencor Z-Stage 25 Pin Board 395617 AIT2
KLA-Tencor Tower Light Driver Board 552364 Rev. AB AIT2
Kensington Laboratories 77-4000-6043-01 5-Axis Motherboard PCB Card
QMB250 Edwards A301-86-905 Vacuum Pump Mechanical Booster Un As-Is
Anelva A12-09242-04A Bellows Cylinder Pair 80x70 ST Lot of 2
Anelva 832-3094-05A Bellows Cylinder Pair
联系人:刘锦燕
手机:13295922579
电话:0592-5580706
传真:0592-5361191
邮箱:LJY_05228@163.COM
QQ:2711934024
QQ:2574619415
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
