- 型号: WESTINGHOUSE 678C276G06
- 数量:10
- 制造商: 厦门兴锐达自动化设备有限公司
WESTINGHOUSE AR/ARB4AR USPP ARARB4AR
WESTINGHOUSE AA13A-J-CTCAS USPP AA13AJCTCAS
WESTINGHOUSE EH-3070 USPP EH3070
WESTINGHOUSE AN11P NSFP AN11P
WESTINGHOUSE BA13JP NSFP BA13JP
WESTINGHOUSE 435C877G01 NSPP 435C877G01
WESTINGHOUSE CB2015FB USPP CB2015FB
WESTINGHOUSE 237A970G01 USPP 237A970G01
WESTINGHOUSE FB3100S USPP FB3100S
WESTINGHOUSE DA2400 USPP DA2400
WESTINGHOUSE 314C386G07 NSFP 314C386G07
WESTINGHOUSE DA3250Y USPP DA3250Y
WESTINGHOUSE DA3250 USPP DA3250
WESTINGHOUSE NLC-1075 USPP NLC1075
WESTINGHOUSE EHD3020 USPP EHD3020
WESTINGHOUSE C23015FB USPP C23015FB
WESTINGHOUSE EHD3015 USPP EHD3015
WESTINGHOUSE GFN423N NSFP GFN423N
WESTINGHOUSE 794A170G15 NSPP 794A170G15
WESTINGHOUSE A10BN0A USPP A10BN0A
FANAL MMS-16 NSFP MMS16
WESTINGHOUSE FT11P-8.0 NSFP FT11P80
WESTINGHOUSE 372D110G04 NSFP 372D110G04
WESTINGHOUSE A060ARB4OOCIG NSPP A060ARB4OOCIG
WESTINGHOUSE BF02F NSPP BF02F
WESTINGHOUSE S-1289371 NSPP S1289371
WESTINGHOUSE FT33P48 NSFP FT33P48
WESTINGHOUSE 229P363H01B USPP 229P363H01B
WESTINGHOUSE NL-1046 USPP NL1046
WESTINGHOUSE 264C901A08 NSFP 264C901A08
WESTINGHOUSE HMCP003A0C USPP HMCP003A0C
WESTINGHOUSE OT1C NSFP OT1C
WESTINGHOUSE C0075C2A NSPP C0075C2A
WESTINGHOUSE 373B331G29 USPP 373B331G29
WESTINGHOUSE L-53-4-5 NSFP L5345
WESTINGHOUSE 677C452G03 NSPP 677C452G03
WESTINGHOUSE BF11F NSFP BF11F
WESTINGHOUSE LE1510A USPP LE1510A
WESTINGHOUSE 487A211G01 USPP 487A211G01
WESTINGHOUSE CB2015 USPP CB2015
WESTINGHOUSE HFD1050L NSFP HFD1050L
WESTINGHOUSE 373D958G06 NSFP 373D958G06
WESTINGHOUSE 61E7453 USPP 61E7453
WESTINGHOUSE 129A519G01 NSPP 129A519G01
WESTINGHOUSE F3050S USPP F3050S
WESTINGHOUSE HFN361 USPP HFN361
WESTINGHOUSE EHD3060L USPP EHD3060L
WESTINGHOUSE 505C806G18 USPP 505C806G18
WESTINGHOUSE 5158C04G08 USPP 5158C04G08
WESTINGHOUSE 1F-0893 NSPP 1F0893
WESTINGHOUSE I289378 USPP I289378
WESTINGHOUSE A12NC1200 USPP A12NC1200
WESTINGHOUSE OT3PG USPP OT3PG
Intersil公司推出一款降压-升压稳压器---ISL9120,可帮助实现对系统电源、Wi-Fi、蓝牙、内存卡或LCD模块等外围设备的高效电源管理。其自适应电流限制PFM架构提供最高98%的业内领先电源管理效率,同时实现降压模式与升压模式之间的平滑转换,可有效的避免毛刺产生,从而可以应用于对轻载效率和快速瞬态响应要求苛刻的场合。其超小外形使ISL9120非常适合用于使用电池供电的、强调移动性的电子产品,例如使用单芯锂离子或锂-聚合物电池,或者两节碱性、镍镉或镍锰电池的可穿戴设备、智能手机、智能恒温器和销售终端设备等等。
由于移动设备的广泛普及和可穿戴设备的日益流行,电源设计工程师面临如何平衡成本、外形和电源效率的挑战。用于可穿戴设备的传统典型电源使用三个DC-DC稳压器和3-5个LDO(低压差线性稳压器),这会占用宝贵的电路板空间。另外LDO也不具备降压-升压稳压器的高效率和可靠性,还会牺牲性能。例如,如果用LDO为使用输出电压接近3.3V的锂离子电池的系统中的外设供电,则来自应用处理器的大突发电流会造成输入电压降至低于LDO调节电压,导致内存重置或系统停止运行。为解决这一问题,ISL9120降压-升压开关稳压器支持更宽的输入电压范围,并通过提供升压来避免当输入电压降至低于输出电压时,出现低压毛刺而使电池掉电。由于ISL9120只需要一个电感,并采用1.41mm x 1.41mm小尺寸封装,所以设计工程师无需在效率或外形上有所妥协。
ISL9120支持1.8V - 5.5V输入电压和1V - 5.2V可调节输出电压为设计工程师提供了满足各种设计需求的灵活性。其自适应PFM架构(包括对强制旁路模式的支持)和 2A 开关功率管既支持低负载电流也支持高负载电流,并保持一致的高效率,从而确保更长的电池续航时间和更少的热量生成。另外,该稳压器还提供800mA输出电流(2.5V输入电压和3.3V输出电压)。在无需电压调节的系统活跃期间,ISL9120会进入强制旁路模式,这可使静态电流降至小于0.5uA的极低水平。
Intersil移动电源产品高级副总裁Andrew Cowell表示:“Intersil的创新自适应PFM架构可满足针对可穿戴设备和其他4G、Wi-Fi便携产品等IoT联网节点的最关键的低功耗设计要求。新型ISL9120稳压器的小尺寸、业内领先的效率、降压-升压模式之间的平滑转换、以及对大负载阶跃的快速瞬态响应对客户极具吸引力。”
主要特性和规格
? 可达98%的超高效率,帮助减小电力消耗和热量生成
? 接受1.8V - 5.5V宽输入电压范围,支持多种电池拓扑
? 1V - 5.2V大的可调节输出电压范围,可支持多个电源轨
? 输出电流可达800mA(Vin = 2.5V, Vout = 3.3V)
? 2A开关功率管既支持高负载电流也支持低负载电流,并保持高效率
? 采用1.41mm x 1.41mm封装的超小外形,帮助节省电路板空间,只需一个电感
? 41uA静态电流最大限度提高轻负载效率,帮助降低功耗
? 自动和可选择强制旁路省电模式使静态电流减小至低于0.5uA
? 欠压、短路及过温全面保护
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
WESTINGHOUSE FB2015 USPP FB2015
WESTINGHOUSE 4975D71G24 USPP 4975D71G24
WESTINGHOUSE 369D830G01 NSFP 369D830G01
WESTINGHOUSE S-943152D NSPP S943152D
WESTINGHOUSE M33-1A NSFP M331A
WESTINGHOUSE 505C806G16 NSFP 505C806G16
WESTINGHOUSE 1532382 USPP 1532382
WESTINGHOUSE AN23A USPP AN23A
WESTINGHOUSE DA-2215 USPP DA2215
WESTINGHOUSE 2380C91G03 USPP 2380C91G03
WESTINGHOUSE 505G806G07 USPP 505G806G07
WESTINGHOUSE EHD3030 USPP EHD3030
WESTINGHOUSE S-1303512-A USPP S1303512A
联系人:刘锦燕
手机:13295922579
电话:0592-5580706
传真:0592-5361191
邮箱:LJY_05228@163.COM
QQ:2711934024
QQ:2574619415
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
工控宝APP下载安装
