- 型号: BX 265 5.25 " 1.9 35/70mm Cine Lens 4
- 数量:1
- 制造商: 厦门兴锐达自动化设备有限公司
- 有效期:2019/1/31 0:00:00
联系人:刘经理
手机:15359273796 与微信号一致
电话:0592-5580706
Wandel & Goltermann RS-100 White Noise Generator
National Instruments PXI-8196
Vickers Hydraulic Power Unit, 5 Gal Per Minute
NHI NHI-2040MW-10L Solid State Amplifier
Beckman L5B-CT Ultracentrifuge with Rotor
HP 5183T Precision Digitizing Oscilloscope
Anelva PRF-153B RF Generator
Rapid-Air R34F Stock Reel
Spirent SR5059 RF Signal
Mystaire 2450 Ductless
Spirent TAS5200i IF Converter
Lindberg / Blue M Thermo GO1330A-1 Gravity Oven
LaserMike 500-02
Carpenter 48 Flat Cable Stripper (Reduced 1/12)
HP 83470A K71 Lightwave Reference Transmitter
LaserMike 60-05-09
LaserMike 50-03
Weinschel 8310 Series 6268 SmartStep? Attenuator Unit
Tek-Temp NRH450 Recirculating Heater with Options
Marconi 2305
Agilent N4483A Noise Parameter Test Set (Reduced 10/11)
Vestil EHLTX-4855-1-39 Hydrolic Scissor Lift
HP 83590A Sweep Generator Module, w/ opt 004
Quadtech 1870 AC DC Dielectric Analyzer
OCE G6035-S Scanner
Budzar / Shini BWA-STM-1220-LT?-460 Oil
TTC T-Berd 310 Communications Analyzer w/ opt's
HP Agilent 35689B S-Parameter Test Set, 150 MHz
Pelton & Crane Validator 10 Autoclave Sterilizer
Leybold S16B Trivac Rotary Vane Vacuum Pump w/AEG Motor
Watson Marlow Trio Close Coupled Pump
HP 54620C Logic Analyzer
HP E1431A VXI Digitizer Module 8-Channel, New In Box
Plasma-Therm, Inc. PE-1000 AC Plasma Power Source
Watson PS2-CB-1 Single Position Payoff (Reduced 2/12)
HP Agilent E1413C High-Speed 64-Channel Converter
HP 8662A Synthesized Signal Generator (Reduced 3/12)
ENI OEM-650A XL RF Generator
Watson Marlow 620RE4 Pump Head w/Nord SK71/4 Motor & No
LeCroy 9354M Digital Oscilloscope w/ opt's (Reduced 10/
HP Agilent 8922M GSM Mobile Station Test Set w/ Opt's
New York Blower Co. 2610A Pressure Blower
HP 89605A RF Input and Calibration Modules
Tektronix PQA300 Picture Quality Analysis System Comple
TTC 2000 Integrated Test Platform w/ TTC 2209 Module (R
Continental CMA-202R Aircooled Liquid Chiller (Reduced
WaveTek 1395 Arbitrary Waveform Synthesizer
HP 11729C Carrier Noise Test Set, 10MHz to 18GHz (Reduc
Solartron 7151 Computing Digital Multimeter (Reduced 10
HP 83404A Lightwave Source Module
NBSC InnOva 2100 Platform Shaker w/ User Manual
HP 70900B Local Oscillator Module (Reduced 10/11)
GL Communication Inc. 9121TB1G8CE
LeCroy 9350AM Digital Oscilloscope w/ Options
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
下一篇:HIMA F3322
工控宝APP下载安装
