- 型号:P68700-00550
- 数量:3
- 制造商: 厦门兴锐达自动化设备有限公司
- 有效期:2019/9/6 0:00:00
ADEPT TECHNOLOGY P68700-00550
局部升温
CNC系统经过长期运行后元器件均要老化,性能会变坏。当它们尚未完全损坏时,出现的故障变得时有时无。这时可用热吹风机或电烙铁等来局部升温被怀疑的元器件,加速其老化,以便彻底暴露故障部件。当然,采用此法时,一定要注意元器件的温度参数等,不要将原来是好的器件烤坏。10.原理分析法
根据CNC系统的组成原理,可从逻辑上分析各点的逻辑电平和特征参数(如电压值或波形),然后用万用表、逻辑笔、示波器或逻辑分析仪进行测量、分析和比较,从而对故障定位。运用这种方法,要求维修人员必须对整个系统或每个电路的原理有清楚的、较深的了解。
除了以上常用的故障检查测试方法外,还有拔板法,电压拉偏法,开环检测法以及在上章中曾提出的诊断方法等多种。这些检查方法各有特点,按照不同的故障现象,可以同时选择几种方法灵活应用,对故障进行综合分析,才能逐步缩小故障范围,较快地排除故障。
ADEPT TECHNOLOGY 30330-15000
ADEPT TECHNOLOGY 10337-15200
ADEPT TECHNOLOGY ADEPT 10841-01202
ADEPT TECHNOLOGY 10332-11506
ADEPT TECHNOLOGY 10341-10010
ADEPT TECHNOLOGY 10330-00088
ADEPT TECHNOLOGY 10332-31150
ADEPT TECHNOLOGY Adept 30400-20000
ADEPT TECHNOLOGY 10338-53005
ADEPT TECHNOLOGY 30330-25000
ADEPT TECHNOLOGY 10337-15200X
ADEPT TECHNOLOGY 90133-48050C
ADEPT TECHNOLOGY 10332-22000 PC Board
ADEPT TECHNOLOGY 30330-31000
ADEPT TECHNOLOGY 10332-31154
ADEPT TECHNOLOGY 10330-10150
ADEPT TECHNOLOGY 10310-58020
ADEPT TECHNOLOGY 10300-11200
ADEPT TECHNOLOGY 10332-48712
ADEPT TECHNOLOGY ASSY 10350-00104
ADEPT TECHNOLOGY 10133-11000
ADEPT TECHNOLOGY 10840-13102
ADEPT TECHNOLOGY MV-19 30330-25000
ADEPT TECHNOLOGY 10840-13430
ADEPT TECHNOLOGY 90400-20035
ADEPT TECHNOLOGY 10604-00100
ADEPT TECHNOLOGY 09228-901
ADEPT TECHNOLOGY 10335-00433
ADEPT TECHNOLOGY MV-8 30330-15000
ADEPT TECHNOLOGY 10330-00400
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
工控宝APP下载安装
