- CPU:Intel® Celeron M 1G /512K
- Chipset:Intel® 910GMLE+ICH6M
- Memory:1 x 200-pin DDR2 400/533 SO-DIMM max. up to 2GB
- Ethernet:Intel 82562EZ 10/100 LAN 82573L Gigabit LAN
- Dimensions:315(W) x 247(H) x 68(D) mm
- Weight:5.2 kg
- OS Support:Windows XP Embedded, Linux (Fedora 2.6), WinCE 6.0
- Serial:2 x RS-232
- USB:2 x USB 2.0
- Audio:1 x AC97 codec with 2W Amplifier (Internal)
- CF Card Socket:1 (internal)
- Ethernet:1 x RJ45 connector for 10/100 base T
- Mini PCIe Socket:1 (Internal)
电源
- DC Input Voltage:Wide range 12-24V DC/DC input
环境可靠性
- Operating Temperature : 0~50℃(with HDD ) / -10~60℃ (with wide temperature SSD)
- Storage Temperature :-20~60℃ (with HDD ) / -30~80℃ (with wide temperature SSD)
- Humidity:5%~95% RH, non-condensing
- Certifications:CE, FCC, VCCI
- Protection Class:IP67
