Specifications
系统 |
- CPU:Intel Atom N450 1.66GHz
- Chipset:ICH8M
- Memory:1 x SO-DIMM supports DDR2-667 MHz
- Storage:1 x 2.5" SATA HDD / SSD, 1 x CF type I/II socket
- Chassis:Aluminum fanless
- Mounting:Wall mount, VESA mount (Optional)
- Dimensions:166 (W) x 147(D) x 56 (H) mm
- OS Support:Windows CE, Windows XP Embedded ready
I/O 接口 |
- Serial:6 x RS-232
- USB:4 x USB 2.0 (2 in front, 2 in rear panel)
- Audio:1 x Phone-out, Mic-in
- VGA:1 x D-SUB15
- Ethernet:2 x 10/100/1000 Ethernet RJ-45
- Wireless:Support 802.11 b/g/n, with external antenna
- LED Indicators:Power, HDD
- PS/2:1 x PS/2 for mouse and keyboard
电源 |
- Power Input:DC 12V
- Adapter:40W AC adapter included
环境可靠性 |
- Operating Temperature:0°C ~ 50°C (with SSD / CF) , 0°C ~ 40°C (with HDD)
- Humidity:95% (Non-condensing)
- Shock Resistance:50G @ wall mount half sine 11ms with CF / 20G @ wall mount half sine 11ms with HDD
- Vibration Resistance:2 Grms @ 5~500 Hz with CF / 0.5Grms @ 5~500 Hz with HDD
- Certifications:CE, FCC
订购资讯 |
- AS-N450G2W:Intel ATOM fanless embedded computer w/ Dual GbE, 6 x serial, VGA, 4 x USB, WiFi and Audio
包装列表 |
- 1 x AC power adapter
- 1 x Wall mounting brackets
- 1 x Quick Setup Guide
- 1 x Utility CD
