CEJN开口安全型快速接头
IT IS TIME TO ANNOUNCE the new name of CEJN’s new premium couplings. 3C has been used as the project name and with launch phase closing up we were recommended to change the name due to intellectual property rights. After some time and adjustment the name eSafe grew and we are confident that the new name will carry out the many values of the new generation couplings. eSafe will leave the customer with a powerful name, loaded with sales arguments easily remembered by the name. The e provides you with no less than six words filled with a multitude of arguments and good values.
environment – a high flow, durable, compact design features resulting in less environmental impactergonomic – safety coupling, compact, easy handlingefficient – high flow = low pressure drop = better tool performanceenergy saving – less air consumption and lower pressure needed economic – reduced air system costseasy handling – low connecting force, easy grip, compact , easy to disconnect
By adding Safe, the name clearly states one of the main features and benefits with the new generation premium couplings from CEJN.
CEJN开口安全型快速接头
希恩公司 WEO接头助力Palfinger 起重机
希恩 WEO接头 产品应用于挖掘设备
希恩WEO接头应用于伐木设备
希恩 WEO 产品助力Brokk 破拆机器
CEJN WEO 接头应用于旋挖机
