CSM15-AT
15" Intel AtomTM N270 1.6GHz Medical PC with Bluetooth, WLAN and Battery
强固式桌面型电脑CSM15-AT
医疗或病床边娱乐系统应用
低功耗Intel AtomTM N270 1.6GHz
无风扇设计
前面板IP-54 泼溅, 灰尘防护
双锂电池(7,200mAh and 1880mAh) ,长工作时间(5.5hrs)
多种通讯接入方式(蓝牙/无线局域网/千兆网)
多种扩展方式(Mini-Card/Smart Card Reader)
系统
CPU Intel AtomTM N270 1.6GHz, FSB 533MHz/512K L2 Cache
图形控制器Intel GMA950 Video Controller, up to 192MB shared memory
内存1 x 200-pin DDRII 667MHz SO-DIMM 1GB (Up to 2GB)
芯片组Intel 945GSE + ICH7M
SATA 1 x Serial ATA 300MB/s HDD transfer rate
外设
串口2 x RS-232 ports
USB 接口4 x USB 2.0 ports
键盘和鼠标1 x PS2 K/B, 1 x Mouse
网络2 x Intel, WG82574L Gigabit LAN
VGA 1 x DB15 VGA port
Wi-Fi 1 x 802.11 b/g USB Wireless LAN Card with antenna
(M1526/N270-F only)
蓝牙1 x Bluetooth module (M1526/N270-F only)
智能卡读卡器1 x Smart Card Reader
CCD 摄像头1 x 2.0 megapixel CMOS camera
扩展总线1 x PCIe Mini-card (USB 2.0 or PCIe interface)
开关及按键
功能键8 x programmable function keys (F1" C F8)
警告灯Programmable for function key
电源开关On/Off
LED 指示灯3 x LEDs on front panel (Battery, Power, Storage)
音频
解码器/接口Azalia HD Audio Codec (ALC888)
Internal 2 x speakers (1.5W), Microphone built-in
LCD显示
尺寸/类型15" TFT Color LCD/1 Channel 24-bit LVDS
最大显示分辨率1024 x 768, XGA
最多色彩数16.2M colors
亮度225 cd/m²
视角130
对比度700 : 1
LCD/背光MTBF 30,000 hours
触摸屏
类型Analog Resistive
透光率80%
控制接口USB Interface
存储
HDD/类型1 x 2.5" SATAII HDD bay
电源适配器
AC 输入100 ~ 240VAC (Full Range)
频率47 ~ 63Hz
DC 输出65W (Max.), 3.5A/19VDC
输入电流(rms) 0.65A/100VAC, 0.27A/240VAC (Max.)
电池
Dual Li-battery pack built-in (7200mAh and 1880mAh)
(M1526/N270-F only)
机构与环境
工作温度0 ~ 40°C (32 ~ 104°F)
工作湿度5 ~ 85% (non-condensing)
尺寸(WxDxH) 409 x 58 x 341 mm (16.1" x 2.28" x 13.43")
抗振性17 to 500Hz, 1G PTP
抗冲击性10G/peak (11ms)
机构材质Plastic
固定VESA-75/100 compatible
防护等级Front panel: IP54 splashproof, dust resistant
认证EMI, CE, FCC class-B, ROHS
