CSM66-PM
10.4" Intel Pentium M 1.1GHz Rugged Tablet PC with Resistive Touch Screen
强固式桌面型电脑CSM66-PM
低反射高效带触摸屏10.4" TFT LCD
抗震动抗跌落军用标准
防水防尘(符合IP68)
宽温(-40 ~ 60°C) 工作温度
多接口(可选无线/蓝牙)
多扩展(内置PCMCIA,CF卡,Mini-PCI Socket)
Multi-Expansion (Built-in , CompactFlash, and )
AC (默认) or DC (9-36V or 48V) 电源输入
4 or 8 x RS-422 接口扩展(可选)
高亮1,000 cd/m2 ,抗强光LCD 显示l(可选)
系统
CPU Intel Pentium M LV 1.1GHz (FSB400MHz) CPU soldered
图形控制器1MB L2 cache built-in Pentium M 1.1GHz CPU
内存256MB DDR RAM soldered + 200-pin DDR DIMM socket
(up to 1GB), upgradable up to 1.25GB totally
芯片组Intel 915GM + ICH6M
声卡ALC202A AC97 Codec
网络1 x Realtek RTL8100 10/100 base-T Fast LAN
闪存1 x 1.8" IDE 4GB flash disk built-in (Optional to 16GB)
I/O
I/O 接口
Through MCK-100: 2 x COM (RS-232C) ports, 1 x VGA
(DB-15) port, 1 x Audio (Speaker-out), 1 x MIC-in, 1 x LAN
(Female RJ-45) port, 2 x USB 2.0 ports
I/O 连接器1 x D38999/26WE35PN (55-pin) Mil-Std I/O connector
I/O 防护等级Mil-Std D38999/33W17R
扩展总线1) 1 x PCMCIA Card-Bus (Type III) socket
2) 1 x Mini PCI socket
3) 1 x CompactFlash socket
功能键12 x Function Keys (8 x Programmable, F1~ F8)
LCD 显示
尺寸/类型10.4" TFT LCD
最大显示分辨率1024 x 768, XGA
Pixel Pitch (mm) 0.264(H) x 0.264(V)
对比度600 : 1
最多色彩数266,144 colors
亮度400 cd/m² (Optional to 1,000 cd/m²)
视角
(CR>=10)
80°~80° (H); 65°~65° (V)
背光MTBF 50,000 hours (20 ~ 35°C)
触摸屏
类型Analog Resistive (4-wire)
透光率80%
控制接口USB Interface
电源适配器
AC 输入100 ~ 240V 1.7A, 50 ~ 60Hz
DC 输出65W (Max.), DC 20V@3.25A
适配连接器Mil-Std D38999 (MS3112E 8-4P)
电池4-cells Li-battery pack built-in, 3900mAh, 3 hrs
battery life
机构与环境
工作温度-40°C to 60°C (-40°F to 140°F)
工作湿度-40°C to 70°C (-40°F to 158°F)
尺寸(WxDxH) 340.3 x 50.75 x 225 mm (13.4" x 2" x 8.9")
净重(Net) 3.5kg with battery (7.7lb)
防护等级IP-68 Rain & Dust Resistant
抗冲击性40G (11ms, 3 shocks/direction, 6 directions)
抗振性6G (20 ~ 2000Hz, 3 times direction, 3 axes)
(Mil-Std-810F, Method 514.4, Procedure 1
Mil-Std-810F, Method 514.4 & 512.2, Procedure 1)
外壳材料6061-T6 Aluminum Alloy
Case Finish HardAnodizing per Mil-A-8625D
订货信息
CSM66-PM
10.4" Intel Pentium M 1.1GHz rugged Tablet PC,
256MB DDR RAM, 1.8" IDE 4GB flash disk, 60W
AC-DC power adapter, resistive touch screen and
carry bag
UMK-6600 CSM66-PM universal mounting kit
MCK-6600
CSM66-PM Mil-Std I/O cable kit, including 2 x COM
(RS-232C) ports, 1 x VGA (DB-15) port, 1 x Audio
(Speaker-out), 1 x MIC-in, 1 x LAN (Female RJ-45)
D38999/26WE35PN CSM66-PM MIL-STD 55-pin connector
D38999/MS3116F-
8-4S (D-D)
CSM66-PM DC-DC 60Wpower adapter (DC9-36V input)
D38999/MS3116F-
8-4S (A-D)
CSM66-PM AC-DC60Wpower adapter (AC100-240V input)
可选件Transportation hard case
USB interface Bluetooth module
Mini PCI WLAN module (IEEE 802.11b/g)
DC9-36V or DC48V power input
4 or 8 x RS-422 ports expansion module
