CONTEC PCI总线 隔离型数字量I/O接口板
2012/2/9 0:17:44
This product is the interface board of the PCI bus conformity which outputs and inputs a digital signal. The board is capable up to 16 input and 16 output. The driver (API-PAC(W32)) for Windows and Linux appending.
产品分类:工控机 外围产品 I/O模件 分布式I/O
品牌:康泰克
Features
- Because of the common composition of a 16-point unit, each common line can respond to a different external power supply.
- Since the PCI bus (personal computer) and the input/output interface are isolated by the photo-coupler, it excels in noise-protection nature.
- All the input signals can be used as an interruption input. Moreover, the edge of the input signal can also generates interruption.
- It has the digital filter function for preventing the incorrect input by the noise or the chatering.
- The rating of an output signal is a maximum of 35 VDC and 100mA per point. The zener diode is connected to the output transistor for protection from surge voltage. Moreover, the over-current protection element is attached per eight output transistors.
- PIO-16/16L(PCI)H, and PIO-16/16L(PCI) are connector pin compatibles.
工业物联网“CONPROSYS™ M2M网关系列”支持楼宇自动化通信协议“BACnet”
工业用计算机的基础知识( 四 ) (显示器接口)
康泰克最新推出 - 采用新散热技术将工作温度范围扩展了多达40%的 大功率无风扇嵌入式PC“盒式计算机 BX-M2510”
工业用计算机的基础知识( 三) (扩展插槽)
边缘计算 / 工业用计算机的基础知识(一) (CPU/芯片组)
