LCR 表
precision measurement of resistors, fuses, thermo-electric coolers, connectors, fine wire switches, thermistors and other low-inductance, resistive devices,excellent choice for applications using laser trimmers.Designed especially for high volume production testing
产品分类:仪器仪表 其它 分析测试仪表
品牌:产品介绍
详细信息
产品名称: 高速可编程微欧姆表
产品型号: 1750
厂商名称: Tegam
Recognized as the industry's fastest precision, micro ohmmeter, the model 1750 has become the #1 choice for manufacturing engineers, QA managers and product engineers who are responsible for high-speed, tight tolerance manufacturing processes.
FEATURES: .02% Basic Accuracy, 100 n resolution, 12mS to first reading, variable test currents, GPIB & RS232 standard communications, Kelvin Klips, Spade Lugs or Kelvin Probes available, 1 year warranty
产品名称: 42.0Hz~5.00MHz, 可编程序的阻抗/LCR 测试仪
产品型号: 3550
厂商名称: Tegam
The New Model 3550 42.0 Hz to 5.00 MHz
Programmable Impedance/LCR Meter offers the
best cost/performance value on the market.
The Model 3550 Programmable Impedance/LCR Meter tests within the extensive frequency range of 42.0 Hz to 5.00 MHz. It measures L, C, R, |Z|, Y, D, Q, R, Phase, G, X, B, V, I, F, in series or parallel modes. With a basic accuracy of 0.10%, the 3550 is designed for a wide variety of automated or manual test applications. RS-232C & I/O interfaces are standard; GPIB or BCD interfaces are optional.
Component test, materials characterization, incoming inspection, high frequency profiling, and other tests that require user-defined test frequency, voltage, and current
产品型号: 252/253
厂商名称: Tegam
TEGAM's Models 252 & 253 are equivalent to ESI 252 & 253. Perfect for component inspectors or manufacturing operators performing manual testing of inductors, capacitors, or resistors.
General-purpose component testing, manufacturing, portable LCR measurement applications, Fenwal temperature sensors testing, thermo-electric cooling devices, large value capacitor and inductor testing, portable field testing of reactive and resistive components.
产品名称: 高准确性、可编程序LCR测试仪
产品型号: 3525
厂商名称: Tegam
Manual component testing and sorting, capacitors, inductors, coils, resistors, materials, thermoelectric cooling devices, piezoelectric sensors and other sensors or components. Great for general-purpose lab use, educational use, QA, and more.
Chart HALT/HASS试验箱解决方案特点介绍
Chart真空绝热管道
电池管理系统测试平台
动力电池充放电系统
直流马达测试方案
