2550B系列射频微波信号源
The 2550B Microwave Signal Generator delivers industry-best offset phase noise performance, high output power, and fast frequency switching speeds in a single unit.
产品分类:无线通信 物联网 网络层 无线通信产品
品牌:产品介绍
详细信息
- 频率范围 100KHz – 50GHz
- 最高输出功率 15dBm
- 最快频率切换速度 500us
- 优异的单边带相位噪声指标
- 支持内外AM, FM, 脉冲调制功能
- 支持GPIB, LAN, USB远程控制
The 2550B Microwave Signal Generator delivers industry-best offset phase noise performance, high output power, and fast frequency switching speeds in a single unit. Performance features such as high time base stability, frequency modulation (FM), high-speed pulse/square wave modulation (PM), amplitude modulation (AM) and high leveled output power makes it an excellent test solution for a wide range of CW, modulation, swept frequency, and fast frequency switching applications in both R&D and manufacturing environment.
Advanced Synthesizer Technology
The 2500B series Microwave Signal Generator utilizes new Advanced Synthesizer Technology that delivers excellent close in phase noise performance of -77dBc @ 100 Hz and -96dBc @ 1KHz and an ultra low phase noise performance of -109 dBc @ 10 kHz and 100 kHz offset on a 10 GHz carrier frequency.
Faster to Program
Every 2500B Microwave Signal Generator comes with Giga-tronics Automation Xpress, a PC based software package designed for enhanced user interface and automatic test systems. The Automation Xpress CD includes a full-featured plug-and-play driver and soft front panels to provide the ATE system integrator with everything needed to get up and running fast. A comprehensive LIST mode, Command-Line interpreter with script and loop capability, and GPIB traffic monitoring are just a few of the many features a test system programmer will appreciate when developing and debugging Test Program Sets.
- Frequency range: 100 kHz to 50 GHz
- Output power: +13 dBm at 50 GHz
- +10 dBm with Step Attenuator option at 50 GHz
- Standard Low Phase Noise
- -109 dBc/Hz at 10 GHz and 10 kHz offset
- Ultra-low close-in Phase Noise option
- -90 dBc/Hz at 10 GHz and 100 Hz offset
- -70 dBc/Hz at 10 GHz and 10 Hz offset
- High Stability Time Base for outstanding frequency accuracy
- 0.001 Hz frequency resolution
- Excellent Spectral Purity
- Harmonics < -55 dBc
- Sub-harmonics < -60 dBc
- Spurious < -58 dBc
- Phase Modulation
- Rate 100 Hz to 100 kHz
- Peak Dev 10 rad-pk/N
- Pulse Burst mode
- 1 to 300 pulses/burst
- Set pulse width, rep rate and burst period
- Electronic Attenuator option (2508B only)
- 110 dB range
- Power Boost mode option
- USB and Ethernet LAN interface
- Emulation Modes, now standard on all 2500B series Microwave Signal Generators (not all of the commands are available)
Chart HALT/HASS试验箱解决方案特点介绍
Chart真空绝热管道
电池管理系统测试平台
动力电池充放电系统
直流马达测试方案
