无线温度测量系统(Wireless temperature measurement system)
无线温度测量系统由无线温度传感器节点、网关、计算机采集处理软件组成。无线数字信号传输方式消除了长电缆传输带来的噪声干扰,整个测量系统具有极高的测量精度和抗干扰能力。
产品分类:无线通信 物联网 网络层 无线通信产品
品牌:产品介绍
详细信息
无线温度测量系统由无线温度传感器节点、网关、计算机采集处理软件组成。无线数字信号传输方式消除了长电缆传输带来的噪声干扰,整个测量系统具有极高的测量精度和抗干扰能力。无线传感器节点采用无线网状网设备,可以组成庞大的网络结构,支持多达上千个测点同时进行大型结构试验。无线温度测量设备被广泛应用于运动物体、不方便假设线路场所以及危险,有毒,有害等场所的温度测量。本系统采用先进的发射/接收和温度采集设备,便于安装,工作稳定性高,其主要技术指标如下:
- 内置高容量电池;
- 采用低功耗无线mesh模块;
- 高达20KM传输距离;
- IP66设计适用于各种场景的测量;
- 8通道温度测量;
- 内置CJC环境温度传感器;
- 支持热电偶,热敏电阻及半导体温度传感器;
- 24位ADC;
- 8通道数字I/O.
Wireless temperature measurement system contains: Temp sensor, Wireless Node, Wireless Gateway as well as DAQ software. Wireless digital can offer very low noise which compare with long wired cable, so it provides high accuracy result. This system is using wireless mesh equipment and support up to thousands of measurement points in the same network. Wireless temperature measurement system is widely used in moving objects, dangerous, toxic, hazardous places for temperature measurement. The system uses advanced transmitter / receiver and measurement module, it is very easy to be installed and maintenance.
- Embedded High capacity battery.
- Low power consumption Mesh module.
- Up to 20KM transmission range.
- IP66 and Industrial grade.
- 24-bit measurement system.
- 8 input channels.
- 4 sensor types: thermocouples, RTDs (2-, 3-, or 4-wire), thermistors, and semiconductor temperature sensors.
- Built-in ambient temperature sensor.
- Independent temperature inputs.
- 8 digital I/O lines.
Chart HALT/HASS试验箱解决方案特点介绍
Chart真空绝热管道
电池管理系统测试平台
动力电池充放电系统
直流马达测试方案
