嘉兆科技 Starprobe超宽带场强探头
AR设计、生产的超宽带场强探头,由电池供电,包含电场和磁场探头,测量覆盖范围可达100 kHz~60 GHz, 0.4~1,000 V/m, 0.012~17 A/m。每个独立的探头都能覆盖比普通探头更宽的频段范围。此系列探头采用了用户可更换的、可充电的电池供电,并且在更换电池后无需进行重新的校准。超宽带系列场强探头有着更完整的数据接收能力和良好的各向同性、线性,可提供无与伦比的精度和准确度。PF7050探头甚至可以读取雷达波。另外,每个探头都配备了高强度的手提保护箱,保证了更高的可靠性和便携性。
产品分类:仪器仪表 现场仪表
品牌:产品介绍
详细信息
探头型号 |
FP7003 |
FP7018 |
FP7050 |
FP7060 |
FH7103 |
FH7110 |
探头类型 |
Electric (E) field |
Magnetic (H) field |
频率范围 |
± 0.5 dB, 100 kHz–100 MHz ± 1.4 dB, 100 MHz–3 GHz |
± 1.8 dB, 3 MHz–10 MHz ± 0.5 dB, 10 MHz–200 MHz ± 1.4 dB, 200 MHz–8 GHz ± 1.8 dB, 8 GHz–18 GHz |
300 MHz–50 GHz |
± 0.5 dB, 27 MHz–150 MHz ± 0.8 dB, 150 MHz–1 GHz ± 0.5 dB, 1 GHz–40 GHz ± 1 dB, 40 GHz–60 GHz |
± 0.5 dB, 300 kHz–30 MHz
± 0.5 dB, 27–300 MHz ± 0.65 dB, 300 MHz to 750 MHz ± 1.2 dB, 750 MHz to 1 GHz |
模拟相应时间 |
50 usec |
50 usec |
100 usec |
50 usec |
50 usec |
50 usec |
各向同性偏差 |
± 1 dB for f>1MHz |
± 1.5 dB, (10 MHz–8 GHz)± 2 dB (f>8GHz |
± 1 dB |
± 1 dB |
± 1 dB |
± 1 dB |
灵敏度 |
0.4–660 V/m |
0.6–1000 V/m |
8–614 V/m |
0.7–300 V/m |
0.012–17 A/m |
0.025–16 A/m |
线性度 |
± 3 dB (0.4–1.25 V/m) ± 1 dB (1.25–2.5 V/m) ± 0.5 dB (2.5–400 V/m) ± 0.7 dB (400–800 V/m) |
± 3 dB (0.6–1.65V/m) ± 1 dB (1.65–3.3 V/m) ± 0.5 dB (3.3–300 V/m) ± 0.7 (300–1000 V/m) |
± 0.5 dB (39–614 V/m)
+ 2 / –3 dB (1.0–2.0 V/m) ± 1 dB (2–250 V/m) |
± 3 dB (0.017–0.033 A/m) ± 1 dB (0.033–0.066 A/m)) ± 0.5 dB (0.066–3 A/m) ± 1 dB (3–17 A/m) |
± 3 dB (0.025–0.05 A/m) ± 1 dB (0.05–0.1 A/m) ± 0.5 dB (0.1–3 A/m) ± 1 dB (3–16 A/m) |
最大可承受场强 |
1600 V/m CWand 16,000 V/m peak |
1500 V/m CWand 27.5K V pulse |
1600 V/m, CW |
> 35 A/m, CW,350 A/m pulse |
20 A/m CW,200 A/m pulse |
采样率 |
60 Hz, 50 Hz, 5 Hz—user selectable |
数据传输速率 |
>30 samples per second |
供电要求 |
2 built-in NiMH batteries, size AA, rechargeable, changeable by operator, 40 hours operating life per charge. |
探头直径 |
65mm |
65mm |
65mm |
65mm |
120mm |
65mm |
重量 |
350 g |
350 g |
350 g |
350 g |
350 g |
350 g |
工作温度 |
0–50°C |
0–50°C |
0–50°C |
0–50°C |
0–50°C |
0–50°C |
Chart HALT/HASS试验箱解决方案特点介绍
Chart真空绝热管道
电池管理系统测试平台
动力电池充放电系统
直流马达测试方案
