关键字: | 艾讯宏达,H61, PICMG1.3,长卡 |
产品分类: | 工控机 工控机配件 CPU卡 |
品牌: | 艾讯宏达 |
- 产品简介:
- 支持LGA1155 英特尔二代/三代i3/i5/i7/奔腾处理器,采用英特尔H61 PCH芯片组,2个240pin内存插槽,最大支持16GB DDR3 1600MHz内存,2个英特尔千兆网络控制器,4个SATAII接口,4个串口,10个USB接口,1个PCI-Ex16,3个PCI-Ex1,8个PCI(via gold fingers)
>> System
Processor LGA1155 for Intel® Sandy BridgeandIvyBridgei3/i5/i7/Pentium processor
Chipset Intel® H61 PCH
DRAM 2 x 240pin DDR3 1333/1600MHz DIMM up to 16GB
BIOS 8MB AMI BIOS ROM
Power Supply Standard ATX power connector from Backplane, Support AT/ATX Mode Power on
Watchdog Watchdog timer function
Dimension 338mm x126mm
>> I/O Ports
HDD 4 x SATA 2.0 port
Serial Port 4 x COM port (3*RS232 + 1*RS232/422/485)
Parallel 1 x LPT port
Audio Realtek ALC262 2-Channel High Definition Audio, line-out, line-in and Mic
LAN 2 x Intel® 82574L Gigabit Ethernet PHY
USB 10 x USB2.0 (8 by onboard header)
Digital I/O 1 x 8 bits Digital I/O connector
Expansion 1 x PCIe x16 Slot (Support Gen2.0/3.0 by CPU)
3 x PCIe 1x, 8x PCI Slot via gold fingers
>> Display
VGA Support 2048x1600@60Hz maximum Resolution
DVI-D (Optional) 1 x DVI-D port by Pin Header, Support 1920 x 1200@ 60Hz maximum Resolution
>> Environment
Operation Temperature 0°~60°C
Humidity 10~90%
