宜鼎国际 iCF 9000 SLC 记忆卡
宜鼎国际iCF 9000 记忆卡的详细产品介绍。
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
S.M.A.R.T / iSMART disk health monitoring tool
Intelligent error recovery system
Excellent data transfer speed
Anti-vibration mechanical design
Write protection security
Static wear-leveling algorithm support
Enhanced power cycling
Overiew
The iCF 9000 is a low-profile, high-capacity solid-state flash memory solution designed to replace traditional rotating disk drives. Compliant electrically with True IDE Mode and compatible with IDE disk drives, the iCF 9000 works reliably as an embedded data storage system for mobile computing and industrial applications. Extremely lightweight, the iCF 9000 delivers a superior data transfer rate of sequential read and write of up to 100MB/s and 95MB/s respectively.
Benefits
The Innodisk iCF 9000 allows manufacturers to replace traditional rotating disk drives with confidence.
High-mobility, and easy plug-in and plug-out
Supports advanced PIO (0-6), Multiword DMA (0-4), Ultra DMA (0-7) transfer mode, multi-sector transfers, and LBA addressing
Compatible with CF Specifications version 6.0, PC Card standard, IDE standard interface, and ATA standard
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
