宜鼎国际 SATA Slim 3SE
宜鼎国际 SATA Slim 3SE 模块系列产品详细介绍。
产品分类:工控机 工控机配件 存储产品
品牌:产品介绍
Features
?SATA III soultion for industrial field
?iSMART disk health monitoring
?Intelligent error recovery system
?Excellent data transfer speed
?Zero mechanical interference
?Compliant with JEDEC MO-297 standard
Overview
Innodisk SATA Slim 3SE is SATA III 6Gb/s Flash based disk, which designed with standard SATA interface (7+15 SATA connector), and compatible with JEDEC MO-297 standard. With its smaller dimension, SATA Slim 3SE is an alternative solution of 2.5” SSD for those embedded system that may have mechanical and space concerns. Innodisk SATA Slim 3SE operates under SATA III (6.0Gb/s) interface with excellent performance and reliability making it the ideal solution for a variety of applications, including embedded system, and industrial field.
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
