东电化兰达 PAQ65D系列电源模块
2014/4/15 14:28:48
Dual output DC-DC converter 65W
产品分类:工业电源 线性直流电源
品牌:东电化兰达
PAQ65D-SERIES
Model name |
Features
Proprietary circuit technology achieved dual output with high 90% efficiency(5V/3.3V type)
Low-profile type:8.9mm high(terminal length excluded)
Output voltage variable type:available to adjust each output voltage individuality.
No need for heatsinks:Convection cooling/forced air cooling operation
Wide range of operating temperature:-40�C~ 85�C
Specifications(catalog download)(technical data download)
Model | PAQ65D48-2518 | PAQ65D48-3318 | PAQ65D48-3325 | PAQ65D48-5033 | ||||||||||
Input voltage range | DC48V (DC36~76V) | |||||||||||||
Output voltage | 2.5V | 1.8V | 3.3V | 1.8V | 3.3V | 2.5V | 5.0V | 3.3V | ||||||
Output current | 15A | 17A | 15A | 17A | 15A | 17A | 13A | 16A | ||||||
Maximam Output power (Po1 Po2) | 37.5W | 49.5W | 49.5W | 65W | ||||||||||
Maximam Output current (lo1 lo2) | 18A | |||||||||||||
Output voltage adj range | �10% | |||||||||||||
Efficiency (typ.) | 86% | 86% | 87% | 90% | ||||||||||
Cooling | Convection cooling or Forced air | |||||||||||||
Operating ambient temperature | -40~ 85�C (output derating to be caused depending on the temperature condition) | |||||||||||||
Withstand voltage | In-out isolation type : 1.5kVDC,For 1 min., between input and output | |||||||||||||
Standard functions | On/Off control, overcurrent protection, overvoltage protection, overtemperature protection | |||||||||||||
Options |
Safety standards | UL1950 � CSA950 � EN60950 (proposed), CE marking applied | |||||||||||||
Dimensions (W x H x D mm) | 36.8 x 8.9 x 57.9 (lead pin length excluded) |
Product lineup
Model | Output voltage | Output current | Maximam Output wattage (Po1 Po2) | Maximam Output current (lo1 lo2) | |
PAQ65D48-2518 | Vo1 | 2.5V | 15A | 37.5W | 18A |
Vo2 | 1.8V | 17A | |||
PAQ65D48-3318 | Vo1 | 3.3V | 15A | 49.5W | |
PAQ65D48-3325 | Vo1 | 3.3V | 15A | 49.5W | |
Vo2 | 2.5V | 17A | |||
PAQ65D48-5033 | Vo1 | 5V | 13A | 65W | |
Vo2 | 3.3V | 16A |
车规MOSFET技术确保功率开关管的可靠性和强电流处理能力
2023年制造业“开门红”,抢滩大湾区市场锁定DMP工博会
2023钢铁展洽会4月全新起航 将在日照触发更多商机
