东电化兰达 PH300/600S系列电源模块
2014/4/15 14:30:32
Single output DC-DC converter 300W-600W
产品分类:工业电源 线性直流电源
品牌:东电化兰达
PH300S/600S-SERIES
Model name |
Features
CE marking (Low voltage Directive)
Compact DC-DC power module
Large power 300W/600W
High power density : 61.6W/inch� (600W type)
600W type : 146 x 86 x 12.7 mm
300W type : 83 x 86 x 12.7 mmWide baseplate temperature : -20~ 100�C
Conduction coolingWide input voltage range
DC48V input : DC36~76V , DC280V input : DC200~400V2 year warranty
Specifications (catalog download)(technical data download)
Input voltage range |
Output voltage range | 10%(12V~28V types) , -10%~ 20%(3.3V,5V and 48V types ) (By TRM terminal and external resistor) Output voltage range is different according to input voltage. | ||||
line regulation | 0.4%,within nominal input voltage range at constant load (3.3V output : 40mV) | ||||
Load regulation | 0.8%.no load to full load at constant input voltage (3.3V output : 40mV) | ||||
Cooling | Conduction cooling (Heatsink & airflow has to chosen according to instruction manual ) | ||||
Operating ambient temperature | Baseplate temperature : -20~ 100�C (output derating is different according to condition) Ambient temperature : above -20�C | ||||
Withstand voltage |
Safty standard | Approved UL1950,CSA950 and EN60950 | ||||
Fanctions | Over voltage protection , Over current protection, Thermal protection, Remote sensing, Remote on / off control, Inverter good signal (IOG terminal), CS terminal (Load current balancing is possible with external control circuit parallel operation) |
Product lineup
Model name | Output voltage | Output current | Output power | |
PH300S48 (input 48VDC) | PH300S48-3.3 | 3.3V | 50A | 165W |
PH300S48-5 | 5V | 50A | 250W | |
PH300S48-12 | 12V | 25A | 300W | |
PH300S48-15 | 15V | 20A | 300W | |
PH300S48-24 | 24V | 12.6A | 302.4W | |
PH300S48-28 | 28V | 10.8A | 302.4W | |
PH300S48-48 | 48V | 6.3A | 302.4W | |
PH300S280 (input 280VDC) | PH300S280-3.3 | 3.3V | 50A | 165W |
PH300S280-5 | 5V | 50A | 250W | |
PH300S280-12 | 12V | 25A | 300W | |
PH300S280-15 | 15V | 20A | 300W | |
PH300S280-24 | 24V | 12.5A | 300W | |
PH300S280-28 | 28V | 10.8A | 302.4W | |
PH300S280-48 | 48V | 6.3A | 302.4W | |
PH600S280 (input 280VDC) | PH600S280-3.3 | 3.3V | 100A | 330W |
PH600S280-5 | 5V | 100A | 500W | |
PH600S280-12 | 12V | 50A | 600W | |
PH600S280-15 | 15V | 40A | 600W | |
PH600S280-24 | 24V | 25A | 600W | |
PH600S280-28 | 28V | 21.5A | 602W | |
PH600S280-48 | 48V | 12.5A | 600W |
车规MOSFET技术确保功率开关管的可靠性和强电流处理能力
2023年制造业“开门红”,抢滩大湾区市场锁定DMP工博会
2023钢铁展洽会4月全新起航 将在日照触发更多商机
