Westermo L106-S2 网管型以太网交换机
Lynx DSS有几个机型可选,L106-S2是2层网管型设备服务器交换机,Westermo WeOS网络软件操作系统. Lynx DSS具有紧凑的设计和在同类服务器交换机中功耗最低要求的交换机。 Lynx DSS具备4个10/100 Mbit/s光口,和2个串口。其中一个串口可以设置为RS-232,另外一个可以设置为RS-232 or RS-422/485。
产品分类:工业以太网 工业交换机 物联网 网络层 以太网交换机 整机 接入传输交换产品
品牌:威斯特蒙
Power
Operating voltage: 19 to 60 VDC
Rated current: 150 mA (300 mA) @ 24 VDC (with 500 mA USB load)
80 mA (150 mA) @ 48 VDC (with 500 mA USB load)
Interfaces
Ethernet: TX 4 x RJ-45, 10 Mbit/s, 100 Mbit/s,
2 Serial ports (One configurable for RS-232 or RS-422/485)
1 x RJ-45, RS-232: 50 bit/s – 115.2 kbit/s
1 x RJ-45, RS-422/485: 50 bit/s – 2 Mbit/s
Digital I/O: 1 x 4-position detachable screw terminal
USB: 1 x USB 2.0 host interface
Console: 1 x 2.5 mm jack, use only Westermo cable 1211-2027
Temperature
Operating: –40 to +70°C (–40 to +158°F)
Storage & Transport : –50 to +85°C (–58 to +185°F)
Agency approvals and standards compliance
EMC: EN 61000-6-1, Immunity residential environments
EN 61000-6-2, Immunity industrial environments
EN 61000-6-4, Emission industrial environments
EN 55022 +A1, Emission IT equipment
EN 55024, Immunity IT equipment
FCC part 15 Class B
EN 50121-4, Railway signalling and telecommunications apparatus
IEC 62236-4, Railway signalling and telecommunications apparatus
Safety: UL/IEC/EN 60950-1, IT equipment
Marine: DNV Standard for Certification no. 2.4
Westermo新产品DDW-142
Westermo荣获2015年中国轨道交通行业十大工业以太网交换机
Westermo交换机为海洋石油开发提供至关重要的可靠保障
Westermo EDW-120串行适配器
Westermo EDW-100串行适配器
