宜鼎国际 宽温系列DDR3 Load reduced DIMM内存条
宜鼎国际:DDR3 Load reduced DIMM
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
JEDEC standard 1.35V(1.28V~1.45V) & 1.5V(1.425V~1.575V) Power Supply
JEDEC Standard 240-pin Dual In-Line Memory Module
8 bit pre-fetch
On Die Termination with ODT pin
Bi-directional Differential Data Strobe
Average Refresh Period 7.8us at lower then TCASE 85°C, 3.9us at 85°C < TCASE ≤ 95°C
Support IMB function
Gold Finger 30μ"
With HEAT SINK
RoHS Compliant
Overview
Load-reduction DIMM modules are designed with a special buffer to reduce heavy-load data to single-load data (up to 8-rank DIMM). In addition, these modules allow more DIMMs to be added per channel in order to reduce power levels and increase memory capacity and system speed.
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
