宜鼎国际 mSATA D150Q存储卡
mSATA D150Q
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
Static wear leveling algorithm support
S.M.A.R.T / iSMART disk health monitoring tool
Excellent data transfer speed
Write protection security
Built-in thermal sensor
Overview
Innodisk’s mSATA D150Q is designed in a standard mini PCIe form factor with a SATA interface. This unique combination provides fast data transfer rate performance and allows for effective integration in small form factor applications, such as digital signage and notebooks. The mSATA D150Q also supports the SATA II standard (3.0Gb/s) and is compliant with JEDEC MO-300 standards and SATA-IO mini SATA standards. The mSATA D150Q is an SLC-based flash device and is available in capacities from 2GB up to 64GB.
Benefits
The Innodisk mSATA D150Q provides manufacturers with a suitable replacement for hard disk drives (HDDs).
Enables personal computer design to be smaller and more compact
Reduces operation system boot time
Consumes less power than an HDD
Can be configured as a boot device or a data storage device
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
