宜鼎国际 mSATA 2SR存储卡
mSATA 2SR
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
Compliant with MIL-STD-810-F/G
Data Security
Excellent data transfer speed
Conformal coating (Optional)
Overview
Innodisk’s mSATA 2SR is designed in a standard mini PCIe form factor with a SATA interface. It comes with several data security functions, including SEraser, QEraser, Destroy, and Write Protect. The mSATA 2SR also supports the SATA II standard (3.0Gb/s) and is compliant with JEDEC MO-300 standards and SATA-IO mini SATA standards. The mSATA 2SR is an SLC-based flash device and is available in capacities from 4GB up to 64GB.
Benefits
The Innodisk’s mSATA 2SR guarantees maximum protection in harsh environments and continuously stores data safely and securely.
Erases 128GB of data in seven seconds
Resists shock and vibration
Stays within temperature limits
Flushes all buffer data to the flash chip before total power loss
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
