宜鼎国际 ServerDOM™-L 3IE内存卡
ServerDOM™-L 3IE
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
Bootable and compatible with all OS
Better reliability and MTBF than HDD
Small dimension for Blade or 1U servers
Compatible with Intel® RSTe
Cost effective storage solution
SATA Pin 8 VCC to enhance reliability and save space
Customizable for IPMI
Unexpected power loss protection
Overview
Innodisk ServerDOM™ is dedicated to the further of server design. By using ServerDOM™ as a boot drive, there is more space for the hot-swappable data storage devices.
Innodisk ServerDOM™ supports SATA III standard (6.0Gb/s) interface with excellent performance and the innovative Pin8 uses the SATA connector itself as a power supply to drive the device without external cables. It could be connected directly to the SATA on-board socket on customers’ system without additional power cable. Besides, the booting time for operation and the power consumption is less than hard disk drive (HDD), and can work under harsh environment compile with ATA protocol, no additional drives are required, and the SSD can be configured as a boot device or data storage device.
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
