宜鼎国际 CFast 3ME2内存卡
CFast 3ME2
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
Innovative Firmware Algorithm
DRAM-less, 100% data integrity
Excellent random performance
Wide Temperature: -40℃~85 ℃
Supports TRIM/NCQ/SMART
Built in iData Guard
Overview
The Innodisk CFast 3ME2 operates at SATA III 6.0 Gb/s, which offers data transfer rate of read up to 440MB/s. and of sequential write up to 150MB/s. Compliant with CFast 2.0 standard, it is designed with 7+17 pin connector and is SATA compatible. Due to the idle power saving, it reduces 30% power consumption. CFast 3ME2 is featured as small form factor, and suitable for most industrial application.
CFast 3ME2 can work under harsh environment, and complies with ATA protocol. Without additional drives, the disk can be configured as a boot device or data storage device. CFast 3ME2 support hardware write protect to prevent modification of valuable data on a device.
Besides, through Innodisk's enhanced power cycling technology and more capacitors, CFast 3ME2 prevents data loss caused by sudden power failure. By using Innodsik's iSMART, users can not only monitor the operation status of SSD, but also visualize Wear-Leveling status with graphics.
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
