宜鼎国际 CFast 3IE内存卡
CFast 3IE
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
iSLC technology
SATA III interface
Extremely low power consumption
iSMART disk health monitoring
Intelligent error recovery system
Excellent data transfer speed
Hardware write protect
Enhanced power cycling management
Overview
iSLC [3IE series], designed to outdo the endurance, performance and reliability of MLC-based solutions. Through the use of flash management algorithms, iSLC improves SSD endurance up to 20,000 times, increasing lifespans up to 10 times longer than MLC-based solutions. In addition, iSLC improves the performance of solid state drives, with similar write performance of SLC-based solutions, and with data quality that is on par with SLC technologies. The Innodisk iSLC series is cost efficient, boasting excellent benefits at only half the price of SLC-based solutions.
CFast 3IE can work under harsh environment, and complies with ATA protocol. Without additional drives, the disk can be configured as a boot device or data storage device. CFast 3ME support hardware write protect to prevent modification of valuable data on a device. Besides, through Innodisk's enhanced power cycling technology and more capacitors, CFast 3IE prevents data loss caused by sudden power failure. By using Innodsik's iSMART, users can not only monitor the operation status of SSD, but also visualize Wear-Leveling status with graphics.
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
