宜鼎国际 FiD 2.5" SATA 10000 Plus固态硬盘
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
S.M.A.R.T / iSMART disk health monitoring tool
Intelligent error recovery system
TRIM command set supported
Excellent data transfer speed
Anti-vibration mechanical design
Built-in thermal sensor
Overview
The FiD 2.5" SATA 10000 Plus is a cost-effective, mainstream SLC high-capacity flash memory SSD that electrically complies with SATA standards. Supported by TRIM, the sequential read/write performance will not be affected when files are deleted by the garbage collector, while the random data access for small files is enhanced.
Benefits
The Innodisk FiD 2.5" SATA 10000 Plus provides manufacturers with an effective replacement for hard disk drives (HDDs).
Good performance, small seek time, and no latency time
Reduces boot time of the operation system
Consumes less power than an HDD
Able to work in lower or higher temperatures than an HDD
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
