宜鼎国际SATADOM™-ML 3SE3固态硬盘
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
Best boot drive solution for server and embedded system
SATA III interface
High IOPS to reduce boot up timing
Built-in Pin 8 power supply
Intelligent error recovery system
Zero mechanical interference
Anti-vibration mechanical design
iSMART disk health monitoring
Overview
Innodisk Serial ATA Disk on Module (SATADOM™) supports SATA III standard (6.0Gb/s) interface with excellent performance, and SATADOM™-ML 3SE3 is designed as the smallest form factor size that could enhance compatibility with various design applications.
Innodisk’s patented Pin 7 and Pin 8 SATA power supply technologies use the SATA connector itself as a power supply to drive the devicewithout external power cables. It is a 100% cable-less, shock resistant, space saving and plug-and-play storage solution that optimizes airflow and makes the best use of limited board space in embedded and rackmount server systems.
Innodisk SATADOM™-ML 3SE3 effectively reduces the booting time of operation system andthe power consumption is less than hard disk drive (HDD), and complies with ATA protocol, no additional drives are required, and can be configured as a boot device or data storage device.
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
