宜鼎国际CFast 3IE4嵌入式储存卡
宜鼎国际CFast 3IE4
产品分类:工控机 工控元器件 嵌入式系统 存储器 其它 工控机配件 存储产品 FLASH 存储产品
品牌:宜鼎国际
產品特色:
iSLC Technology
Exclusive L³ architecture
Designed with LDPC ECC engine
DRAM-less, 100% data integrity
Excellent random performance
Wide Temperature: -40℃~85 ℃
Supports TRIM/NCQ/SMART
Built in iData Guard
產品介紹:
Innodisk CFast 3IE4 is iSLC series which is designed to outdo the endurance, performance and reliability of MLC-based solutions. Through the use of flash management algorithms, iSLC improves SSD endurance up to 20,000 times, increasing lifespans up to 7 times longer than MLC-based solutions. In addition, iSLC improves the performance of solid state drives, with similar write performance of SLC-based solutions. The InnoDisk iSLC series is cost efficient, boastingexcellent benefits at only half the price of SLC-based solutions.
Innodisk CFast 3IE4 is characterized by L³ architecture with the latest SATA III (6.0GHz) Marvell NAND controller. Innodisk’s exclusive L³architecture is L² architecture multiplied LDPC (Low Density Parity Check). L² (Long Life) architecture is a 4K mapping algorithm that reduces WAF and features a real-time wear leveling algorithm to provide high performance and prolong lifespan with exceptional reliability.
Innodisk CFast 3IE4 is designed for industrial field, and supports several standard features, including TRIM, NCQ, and S.M.A.R.T. In addition, Innodisk’s exclusive industrial-oriented firmware provides a flexible customization service, making itperfect for a variety of industrial applications.
規格:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
