宜鼎国际CFast 3MV2-P嵌入式储存器
宜鼎国际CFast 3MV2-P
产品分类:工控机 工控元器件 存储器 工控机配件 存储产品 FLASH
品牌:宜鼎国际
產品特色:
InnoREC soultion for surveillance application
Exclusive REC line for video recording ensures steady performance without any frame-loss
Built-in thermal sensor
Support S.M.A.R.T, TRIM, NCQ and iData Guard
產品介紹:
InnoREC is innodisk’s proprietary flash feature set designed specifically for surveillance applications. Through the smart integration of firmware and hardware, the speed and performance required by modern surveillance solutions is fully met. Innodisk CFast 3MV2-P is SATA III 6Gb/s flash based disk, which delivers excellent performance, especially in random data transfer rate, and which offers reliability making it the ideal solution for a variety of applications,including surveillance system, embedded system and industrial computing.
Innodisk CFast 3MV2-P supports several standard features, including REC line, TRIM, NCQ, and S.M.A.R.T. Innodisk’s exclusive REC line is ideal for video recording. With steady performance, no need to worry about any frame-loss. CFast 3MV2-P not only performs unmatched performance, but also designed with Innodisk owned technical knowhow to ensure the data integrity and highest levels of reliability.
规格:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
