宜鼎国际mSATA 3MV2-P工业用闪存模块
产品分类:工控机 工控元器件 存储器 工控机配件 存储产品 FLASH
品牌:宜鼎国际
产品特色
SATA 6Gb/s interface
JEDEC MO-300 standard dimension
High IOPS by on-board DRAM design
Intelligent error recovery system
iSMART disk health monitoring
iData Guard for abnormal power failure
Zero mechanical interference
DEVSLP supported
Overview:
InnoREC is innodisk’s proprietary flash feature set designed specifically for surveillance applications. Through the smart integration of firmware and hardware, the speed and performance required by modern surveillance solutions is fully met. M.2 (S80) 3MV2-P products provide high capacity flash memory Solid State Drive (SSD)that electrically complies with Serial ATA (SATA) standard. It supports SATA III standard (6.0GHz) with high performance and supports several features, including REC line, iData Guard, iCell, quick erase, thermal sensor, and S.M.A.R.T.
规格:
产品料号:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
