宜鼎国际SATA Slim 3MV2-P工业用闪存模块
产品分类:工控机 工控元器件 存储器 工控机配件 存储产品 FLASH
品牌:宜鼎国际
产品特色
SATA III soultion for industrial field
High IOPS solution
iData Guard protection
iSMART disk health monitoring
Intelligent error recovery system
Excellent data transfer speed
Zero mechanical interference
Compatible with JEDEC MO-297 standard
Overview:
InnoREC is innodisk’s proprietary flash feature set designed specifically for surveillance applications. Through the smart integration of firmware and hardware, the speed and performance required by modern surveillance solutions is fully met. SATA Slim 3MV2-P products provide high capacity flash memory Solid State Drive (SSD)that electrically complies with Serial ATA (SATA) standard. It supports SATA III standard (6.0GHz) with high performance and supports several features, including REC line, iData Guard, Quick Erase, Thermal sensor, and S.M.A.R.T.
规格:
产品料号:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
