宜鼎国际CFexpress 3TE2工业用闪存模块
产品分类:工控元器件 存储器
品牌:宜鼎国际
产品特色
PCIe Gen. III x2, NVMe 1.2
Excellent data transfer speed
Zero mechanical interference
LDPC ECC engine supported
End-to-end Data Path Protection
Support Write Protect Function
Overview:
Innodisk CFexpress 3TE2 is followed by CFexpress 1.0 type B, with PCIe interface. CFexpress 3TE2 supports PCIe Gen III x2, and it is compliant with NVM 1.2 providing excellent performance. Moreover, it adopts industrial 3D TLC NAND Flash providing high endurance and reliability. With sophisticated error detection and correction (ECC) functions, the module can ensure full End-to-end Data Path Protection that secures the data transmission between host system and NAND Flash.
Innodisk CFexpress 3TE2 is a small and removable memory card providing low latency and extreme speed but with low power consumption and efficient heat dissipation. It is ideal for gaming, edge computing and professional digital recording.
规格:
产品料号:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
