宜鼎国际M.2 (P42) 3IE6工业用闪存模块
产品分类:工控机 工控元器件 存储器 工控机配件 存储产品
品牌:宜鼎国际
产品特色
PCIe Gen. III x2, NVMe 1.3
DRAM-less Solution
Less Controller Heat
Anti-Vibration Mechanical Design
iSLC Mode for Excellent Performance & Endurance
LDPC ECC Engine Supported.
iPowerGuard Protection
Overview:
Innodisk M.2 (P42) 3IE6 is a NVM Express DRAM-less SSD designed with PCIe interface and industrial 3D TLC NAND Flash. M.2 (P42) 3TE6 supports PCIe Gen III x2 and it is compliant with NVM 1.3. With iSLC mode enabled, 3IE6 provides excellent sustaining performance and outstanding endurance. With sophisticated error detection and correction (ECC) functions, the module can ensure full End-to-End data path protection that secures the data transmission between host system and NAND Flash. In addition, with embedded AES-256 bit engine, your data can be further secured.
规格:
产品料号:
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
