- 型号:DSP-FTA430 DSP400
- 数量:1
- 制造商: 厦门兴锐达自动化设备有限公司
关键词: GIS;电压互感器;B类冲击波;传递过电压;测量装置
摘要:摘要:为了测量GIS用互感器的传递过电压,本文利用实验室虚拟仪器工作平台Lab VIEW 8.6(Laboratory Virtual Instrument Engineering Workbench),开发一套适用于互感器传递过电圧试验的测量控制装置。通过该测控装置测量了110kV GIS电压互感器的传递过电压,试验结果表明该装置的B类冲击波产生、控制和测量均能满足国家标准和IEC标准的要求,且使用灵活方便,可靠性高,能很好运用于互感器型式试验中传递过电圧的测量及研究传递过电圧的传递特性。
GIS用互感器的传递过电压测量装置研究
王彦金,王巍
(武汉楚为志远信息科技有限公司,武汉,430074)
关键词:GIS;电压互感器;B类冲击波;传递过电压;测量装置
Study onmeasurement device fortransfer over voltage of GIS transformer
Abstract:In order tomeasure the transfer VFTO of GIS voltage transformer, this paper developed ameasurement and control device which based on Lab VIEW 8.6 Workbench. Usingthis device to test the transmitted over voltage of 110kV GIS Voltagetransformer, the result showed that the device not only can meet therequirements of IEC and national standards, but also be flexible and reliableto use, which can be well applied to the transformer type test and research oftransmitted over voltage characteristics.
Key words:GIS; voltage transformer;B class shock; transfer over voltage; measurement device
0 引 言
气体绝缘开关设备(gas insulatedswitchgear, GIS)中隔离开关例行操作常会引起频率1-100MHz的特快速瞬态过电压(VFTO)[1-2]。电力系统的正常运行中如果这种过电压从高电压系统传递到低电压系统,就有可能对低电压系统的电器设备造成损害,影响电气设备的安全运行[3-4]。GIS电压互感器本身就是电容分压和电磁感应原理进行电压测量的线路器件。由于GIS电压互感器接于线路对地之间,所以这种过电压要传递到二次测量回路,使二次测量设备承受来自一次回路的传递过电压,在GIS运行中也出现过互感器传递过电压造成二次设备危害的问题[5-6]。
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
ball screw
Microscan, FIS-3000-0003, MS-3000 Decoder NEW
Partlow, 4100-000-023-111-00, Process Control Temperature Chart Recorder NEW
Fanuc A03B-0819-C052 Analog Output Module NEW
Mac, 59B-52-RA, 2" 2i Solenoid Valve 150psi NEW
Dynapar 62-CHEF-0720-A0 Rotary Encoder M050705 NEW
Mitsubishi MR-J2S-20A AC Servo Drive Amplifier Inverter
Banner, DX80N9X6S6N6C, 82997, SureCross DX80 Wireless Node NEW
IFM Efector VSE100 Vibration Diagnostic Controller NEW
Kawasaki, 9ZT-31, LCD Display Module NEW
Yaskawa SGMAH-A5A1A-YR21 AC Servo Sigma Motor Without Brake Motoman NEW
GE Fuji Electric 6KG1123F50X1B1 AF-300G11 AC Motor Drive VFD NEW
Mitsubishi FR-E520-1.5KN-TB Inverter Motor Drive Servo Freqrol E500 NEW
Fairchild 3463 Lever Operated Regulator 2-150psig 3400 NEW
SMC ISA15-4R-01BG Air Catch Sensor NEW
Omron, CJ1W-CLK23, Controller Link Unit PLC Module Card NEW
N-Tron 509FX-A-ST DIN mountable enclosure Ethernet Switch 10-30V 1.0A NEW
Bosch 1070075324-102 E24V Input card board module *NEW*
Allen Bradley, 440R-ZBR520AZ1, Guard Master Minotaur Safety Relay NEW
Balluff BOWA-1208-PS-C-S49 Dynamic Optical Window Photoelectric Sensor NEW
AC Tech Lenze SD230 Speed AC Motor Drive 3HP 2.2kW NEW
Warner Electric MCS-805-1 Power Supply 115-230v 90vdc 90v DC NEW
Telemecanique CC3-HB110E bar contactor 400HE4 bobine
Siemens, 6ES5464-8ME11, Analog Input Module PLC Simatic NEW
RL Aarell 9720 meter control gauge gage
Allen Bradley, 22D-D2P3N104, PowerFlex 40 Inverter Motor VFD AC Drive 1hp NEW
Banner, DX80G9M6S6N6C, 83121, SureCross DX80 Gateway w/ Discrete I/O NEW
Yaskawa JANCD-MMM02-2E DF9200720-C2 Replacement Circuit Board System (OBS)
Yaskawa Juspeed-F CIMR-G08C Transistor Inverter Motor Drive Servo Controller NEW
Fanuc A16B-1211-0860/05A PC Board Memory Module Shared RAM Bd A16B1211086005A
PPT Vision 661-0114 strobe light control NEW
Norgren C0030H Air Control Valve Poppet 150PSIG NEW
Siemens ITE JD62T200
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
下一篇:Fluke DSP-400
工控宝APP下载安装
