- 型号:FOXBORO 50-150F
- 数量:1
- 制造商: 厦门兴锐达自动化设备有限公司
[5] 谷定燮,修木洪,戴敏,等.1000kV GIS变电所VFTO特性研究[J].高电压技术2007,33(11):27-32.
GUDingxie,XIU Muhong,DAI Mine al.Study on VFTO of 1000kV GIS Substation[J]. HighVoltage Engineering, 2007, 33(11):27-32.
[6] 郭天兴,徐杰,王璇,等.电容式电压互感器传递过电压的试验研究[J].电力电容器与无功补偿,2008,29(1):23-30.
GUOTianxing,XU Jie,WANG Xuan,et al.Testing investigation on transfer over voltage ofcapacitor voltage transformer[J].Power capacitor and reactive powerCopmensation,2008,29(1):23-30.
[7] 高景明,刘永贵,刘金亮,等.陡化前沿Marx发生器的设计与初步实验[J].强激光与离子束,2008,20(1):167-170.
GAOJangling, LIU Tongue, LIU Jingling, et al.Design and preliminary experimentalresults of wave erection Marx generator [J].High Power Laser and ParticleBeams, 2008, 20(1):167-170(in Chinese).
[8] 陈建.GIS中陡波前过电压特性及影响因素研究[D].华北电力大学硕士学位论文,2006.
CHENJian.Characteristic of very fast transient over voltages in GIS and analysis ofinfluencing factors [D].Master thesis of North China Electric Power University, 2006.
[9] 刘轩东,李登云,孙凤举,等.用于纳秒脉冲高压测量的同轴电容分压器[J].高压电器,2008,44(1):32-36.
LIUXuedong, LI Dengue, SUN Fungus, et alga coaxial capacitive voltage divider fornanosecond pulse measurement [J].High Voltage Apparatus 2008, 44(1):32-36(inChinese).
[10] 凌子恕.高压互感器技术手册[M].北京:中国电力出版社,2005.
[11] GB 20840.1-2010互感器第1部分:互感器通用技术要求.
GB20840.1-2010 Instrument transformers. Part 1: General requirements.
[12] 廖传书,黄道斌等.Lab VIEW与USB的直接数据通信[J].现代电子技术,2007,259(20):4-6.
LIAOChianti, HUANG Daubing, et al.Direct Data Communication between Lab VIEW and USB[J].Modern Electronic Technique,2007,259(20):4-6.
[13] 阚宝风,施乐平,马宪民.基于LABVIEW的冲击测量系统[J]仪器仪表学报,2010,31(8):352-353.
KanBaofeng,Shi Leping,Ma Xianmin.The shock measurement of data acquisition systembased on LABVIEW.[J].Chinese Journal of Scientific Instrument,2010,31(8):352-353.
[14] 张佩,赵书涛等.基于Lab VIEW的变压器直流电阻快速测量系统的设计[J].电工电气2013,7:42-45.
ZHANGPie, ZHAO Shoat, et al.Design of rapid Measurement System for Transformer DCResistance Based on Lab VIEW [J]. Janise Electrical Apparatus, 2013, 7:42-45.
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
YASKAWA ELECTRIC PRINT MOTOR/ DAIHEN CMWH-145 PMEE-12CBB
SIEMENS RAM 64KB 6ES537-0AB31
LUBRQUIP TRABON MODU-FLO PUMP PACKAGE
WATTS IRON BODY REGULATOR VALVE 1065 CWP 200
WESTINGHOUSE OVERCURRENT RELAY 289B988A17A MISSING FRONT COVER
BALDOR 145T 1725RPM 3PH CLASS-B ELECTRIC MOTOR M3157T / 35B01-754 SER-F1188
ULVAC PIRANI SENSOR HEAD WP-02
MURR ELEKTRONIK 24VDC 40A DC POWER SUPPLY MDN 40-200-550/24
KEYENCE SJ-M020G (1.2M) LONIZER
ALLEN BRADLEY 110/120VAC COIL, 3-PHASE, 3-POLE, SIZE 3 STARTER Ser.K 709-DOD103
FURNAS SOLID STATE OVERLOAD RELAY 48BSJ3M20
MTE 0.400MH 80A TRANSFORMER RL-08002
FANUC CABLE A660-4004-T151
ITT TRANSFORMER 415-014-0002 NNB
WESTINGHOUSE 7A 600VAC CURRENT LIMITER EL3007R / 2607D43G08
EATON CUTLER-HAMMER RED JUMBO MUSHROOM HEAD PUSHBUTTON 10250T27R
ANALOG DEVICES 8-CHANNEL BACKPLANE 3B02 IN BOX
INGERSOLL RAND TORQUE CONTROLLER CONNECTION BOARD PCB 1000886
SIEMENS SIRIUS SOLID STATE OVERLOAD RELAY 3RB1046-1UB0
MIDDEX ELECTRONIC TOOL MONITOR MODULE WK 1T
KOBOLD HUMIDITY / TEMPERATURE MEASURING INSTRUMENT AFK-G3T
MARPOSS E9066 RACK MOUNT POWER SUPPLY 6366160501
ARTIS MTC MONITORING MODULE MTC-W1-2 4689-50/02
IDEC IZBARL CONTACT SIGNAL TRANSDUSER IBRC4102FM
SHARP 12/24VDC INPUT MODULE ZW-162N
RED LION CONTROLS PANEL-MOUNT DIGITAL METER IMI04103
SIEMENS 24VDC COIL MANUAL COMBINATION MOTOR CONTROLLER 3RA1110-0HC15-1BB4
ACOPIAN 15V 1.6A LINEAR REGULATED POWER SUPPLY TD15-160
MIRAGE IRCON INFRARED THERMOMETER PROCESSING UNIT MR201020F00/010
INLINE 150 PSI ACTUATOR, AP-UT-21-DA-BN
KAMOSEIKO KAMO 1/18S RATIO BALL REDUCER BR50SH-18S-S011 102910
SQUARE D LIMIT SWITCH C54KC
ASCO 24-240V 1A 50/60HZ ADJUSTABLE ELECTRONIC TIMER, 272839-001,
STATIC CONTROLS CORPORATION CONTROL BOARD PCB CB-0950-001
RELIANCE ELECTRIC S-2000 B79B3194M 3/4 HP PHASE 3 230/460 VOLTS AC MOTOR, NEW
FUJI ELECTRIC TRANSISTOR MODULE A50L-0001-0330
ROSEMOUNT ALPHALINE PRESSURE TRANSMITTER 1151DP4E22B1D1W6
NAMCO PXSW 40mm FLATPAK WFI PROXIMITY SENSOR EE510-18640
NAMCO SNAP-LOCK EA700-80000
SHARP 12/24VDC INPUT/OUTPUT MODULE, ZW-162M
BURKE E PORTER VME ANALOG OUTPUT PCB CARD BEP 3007040
ANALOG DEVICES WB STRAIN GAGE INPUT MODULE 3B18-00
TELEMECANIQUE TSX 24VDC OUTPUT MODULE TSXDST2482
TELEMECANIQUE TSX 240VAC RELAY OUTPUT MODULE TSXDST16345
STATEC CARD INTERFACE, PPS8500DFS2C2
PM FIELD DC SERVO MOTOR MT-2015-008HF
SQUARE D CLASS 8430 PHASE FAILURE RELAY TYPE DASV
UFM FM-1-AL-LP-3EE-300 SSU-4-F3
AEG MODICON MODEL 485K PROGRAMMABLE CONTROLLER 043504912
WAGO-I/O-SYSTEM 750-306/000-005
ALLEN BRADLEY 1321-3R18-B LINE REACTOR 18 AMP 3PH REACTOR
WESTINGHOUSE 40 AMPS 3 POLE 480 VAC CIRCIT BREAKER EHD3040L
GENERAL ELECTRIC VOLTAGE RELAY 12IAV54E2A
TELEMECANIQUE 24VDC COIL 300A STARTER LC1D115
NAMCO 20-250VAC, 400mA, PROXIMITY SWITCH ET120-42400
WAGO 0-10VDC ANALOG OUTPUT MODULE 750-550
FESTO ELECTRIC 24-48VDC STEPPER MOTOR DRIVE SEC-ST-48-6-P01
MIKI PULLEY CONTROL POWER UNIT SYD-P
MEDAR MEDWELD ANALOG FIRING BOARD 3001 900-6423-3
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
上一篇:SWITCH LSA3K-1B
下一篇:SWITCH 829-2-AC
工控宝APP下载安装
