- 型号:30400-20000
- 数量:3
- 制造商: 厦门兴锐达自动化设备有限公司
- 有效期:2019/9/6 0:00:00
ADEPT TECHNOLOGY 30400-20000
数控机床的主轴直流驱动的故障诊断
由于直流调速性能的优越性,直流主轴电动机在数控机床的主轴驱动中得到广泛应用,主轴电动机驱动多采用晶闸管调速的方式。
1.控制电路
调速特点—速度环的输出是电流环的输入,可以根据速度指令电压和转速反馈电压的差值及时控制电动机的转矩。
在速度差值大时,转矩大,速度变化快,转速尽快达到给定值,当转速接近给定值时,转矩自动减小,避免超调.
2.主电路
数控机床直流主轴电动机由于功率较大,切要求正、反转及停止迅速,驱动装置采用三相桥式反并联逻辑无环流可逆变调速系统.
在制动时,除了缩短制动时间,还能将主轴旋转的机械能转变成电能送回电网。还利用逻辑电路,使一组晶闸管工作时,另一组的触发脉冲被封锁,切断两组之间流通的电流。
ADEPT TECHNOLOGY 30330-15000
ADEPT TECHNOLOGY 10337-15200
ADEPT TECHNOLOGY ADEPT 10841-01202
ADEPT TECHNOLOGY 10332-11506
ADEPT TECHNOLOGY 10341-10010
ADEPT TECHNOLOGY 10330-00088
ADEPT TECHNOLOGY 10332-31150
ADEPT TECHNOLOGY Adept 30400-20000
ADEPT TECHNOLOGY 10338-53005
ADEPT TECHNOLOGY 30330-25000
ADEPT TECHNOLOGY 10337-15200X
ADEPT TECHNOLOGY 90133-48050C
ADEPT TECHNOLOGY 10332-22000 PC Board
ADEPT TECHNOLOGY 30330-31000
ADEPT TECHNOLOGY 10332-31154
ADEPT TECHNOLOGY 10330-10150
ADEPT TECHNOLOGY 10310-58020
ADEPT TECHNOLOGY 10300-11200
ADEPT TECHNOLOGY 10332-48712
ADEPT TECHNOLOGY P68700-00550
ADEPT TECHNOLOGY ASSY 10350-00104
ADEPT TECHNOLOGY 10133-11000
ADEPT TECHNOLOGY 10840-13102
ADEPT TECHNOLOGY MV-19 30330-25000
ADEPT TECHNOLOGY 10840-13430
ADEPT TECHNOLOGY 90400-20035
ADEPT TECHNOLOGY 10604-00100
ADEPT TECHNOLOGY 09228-901
ADEPT TECHNOLOGY 10335-00433
ADEPT TECHNOLOGY MV-8 30330-15000
ADEPT TECHNOLOGY 10330-00400
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
工控宝APP下载安装
