- 型号:Tokyo 1D81-000065-1
- 数量:10
- 制造商: 厦门兴锐达自动化设备有限公司
Kokusai Digital Direct Controller Vertron DD803V CQ1500A
Interface IBX-4142 Interface PCB
Sti MC4216E-1-AC1-U-10X-10R-ESD Light Curtain Controller
Millipore MFC Surface Mounts FC-2979MEP5-WM CHF3 Lot of 5 AS-IS
AMAT Applied Materials 0100-01875 AC Distribution Board
Yaskawa VS mini Drive Controller CIMR-XCAA21P5
Lam Research 810-17004-001 Solenoid Interlock PCB Board Rev. D
SVG Spin Station Expansion Board 99-80207-03
AMAT Applied Materials 0020-09316 Plate Blocker Assembly 150mm New
Lam Research 853-002900-010 RF Cable Assembly New
Semitool Output Board Assy. 14831-01
AMAT Applied Materials 0140-01893 PVD Robot Umbilica Harness Assembly New
AMAT Applied Materials 0140-76569 Robot Harness Assembly MF to XFR New
Hitachi 568-5589 PASW PCB Card S-9300 SEM
LAM Research 715-130080-008 200mm End Effector Rev. F
KLA-Tencor AIT 2 Keyboard Breakout Board 547220 Rev.AA
Black Box SW651A ServSwitch Wizard SSW2
Denso Nikon 4S586-274 PZT Driver PZTDriver
Varian E1000 Inner Bushing Shield E17124530 new
Nikon NSR Power Supply 4K177-955-2
Carpenter Ceramics ALPS 894 Clamp Ring IN0440-1003 new
Nor-Cal ANC-NW-16-275 Conical Adapter Nipple Lot of 5 AMAT New
Honeywell 060-3155-01 Display and Signal Conditioner NK
Clean Sciences 15-262478-00 PED Blankoff Novellus C3 Altus Copper
Tokyo 1D81-000065-1
MRC Materials Research Corp D124569-A Dark Space Shield 300mm TEL New
RadiSys SBC 552B PCB Board ASML 879-8103-002
Sanritz Automation SVME/AT-BCN/A PCB Card SVA603A-1S
Soft Switching Technologies DE10001A208V Dynamic Voltage Sag Corrector Mini DYSC
Sti 43268-0160 Light Curtain Controller MINISAFE-B MS4316B-2
Sti 43268-0240 Light Curtain Controller MINISAFE-B MS4324B-2
KLA-Tencor 710-678715-00 SAT Backplane Assembly PCB
Omron NT20S-ST161B-V3 Interactive Display
Affinity PXZ4-SDY2-5V Temperature Controller PXZ-4 Reseller Lot of 12
Fuji Electric PYX4MFY1-204RF Temperature Controller Reseller Lot of 10
Integrated Designs Chemical Dispense Card PCB
Integrated Designs Dispense Mother Board PCB Rev. 201G
Integrated Designs Dispense Mother Board Rev. 202G
Tokyo 1D81-000065-1
产品名称: 噪声在线监测/取证系统
产品型号: ENS系列
基本参数: 无人值守,实时监控
产品介绍:
功能特点
全天候自动监测:防水、防尘、耐高/低温,24小时X365天不停机运行
定时监控:每天或每小时定时采集,采集时间和间隔可灵活设置
噪声限值监控:记录超过法定限值的噪声,不同时间段可设置不同的限值
可同时采集噪声分贝数值和现场高保真背景音频信号
可通过设置报警条件进行噪声事件管理
通过公网传输数据,组网容易,运营成本低
多重容错设计、性能稳定,硬件看门狗技术、永不死机
便携式轻便、小巧,便于携带和现场安装
灵活的数据查询和统计方式,支持噪声音频曲线回放
可集成GIS功能
性能规格
低功耗位嵌入式芯片(300MHZ),64M SDRAM(最大256M
2个标准端口,1个RS-485/422可选端口,4个USB口
10/100M 以太网控制RJ-45接口,1个并行口
高精度毫秒级实时时钟,支持掉电保护及看门狗功能
支持AC97音频接口,麦克风输入、线路输入/输出
工作环境:温度 -10℃~+60℃,湿度 5~90%,不结露
电源供电: DC 5V/1.2A(典型值)
参考的环境噪声标准
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
Progressive Technologies 12352G01 Exhaust Blower Sentry 1000 TEL ACT12 As-Is
Taiyo 1380-101437-11 Z-Base2 CS/IF TEL Tokyo Electron New
TEL Tokyo Electron LPC-T0009A-11 Load Port DC/DC Conv.Board 100-T0009A-11
Fuji Electric VFC304A-7W Ring Compressor
A to Z Electronics 50714800000 FOCI Assembly AMAT Applied Materials SEMVision cX
SIMCO 4002430 Adjustable Power Unit AMAT Applied Materials SEMVision cX
Phoenix Mecano VIF/4-24-PO-115-OPAL Power Supply AMAT SEMVision cX
Opal 30613210100 LVPS Assembly AMAT Applied Materials SEMVision cX
Fortrend 120-1004 Wafer Load Station F-8025 Copper Exposed As-Is
Fortrend 120-1004 Wafer Load Station F8025 Not
Tokyo 1D81-000065-1
Fortrend 120-1004 Wafer Load Station F-8025S As-Is For Parts
Cutler-Hammer HFD-65K 3-Pole Circuit Breaker New
MAC BA-00526-32 32-Stage Pneumatic Manifold Semitool 61590-33 New
L&N Leeds And Nortrup 007498 Circuit Card Semitool 14239
BTI Bruce Technologies 3163361 Torch Control Interface PCB 3163360
TrueVision TVB-563-V4.0 Digital Video PCB Card
MDC AV-150M-P Angle Valve 313029 New
Granville-Phillips 275821 Differential Output Amplifier Lot of 4
JAI Corporation CV-M30 Monochrome Double Speed Camera
Pureron DFM2-1000 Digital Flow Meter Lot of 3
ETP Semra SPIM Robinson Controller Set RDEM-III-LV
Tokyo 1D81-000065-1
Nikon PCB AF-PSDX21 4S007-879-1 Lot of 2
联系人:刘锦燕
手机:13295922579
电话:0592-5580706
传真:0592-5361191
邮箱:LJY_05228@163.COM
QQ:2711934024
QQ:2574619415
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
工控宝APP下载安装
