- 型号:AMAT 0100-94006
- 数量:10
- 制造商: 厦门兴锐达自动化设备有限公司
AMAT 0100-94097 Rev. B Vibration XR80
AMAT 0100-90973 Rev. A Orienter Interlock Board XR80
AMAT 0100-91095 Rev. A Pneumatics Control Board XR80
SMC SS5Y3-02-ULB990057 Pneumatic Manifold AMAT 0010-01801 New
Metron 150mm Heater Shield Ring D115719 Rev.D new
Inficon SKY Capacitance Diaphragm Gauge CR091D
Tescom Pressure Regulator 44-2361-T9-051 new
MRC Materials Research Corp. A115421 Short Tab 150mm Base Weldment Rev.E new
Newport INFT-0000-KF Digital Temperature Display LED Lot of 2
Digitron 4501/4 DPM Thermometer Lot of 4
Unit UFC-8165 Mass Flow Controller Digital UltraClean MFC Lot of 4 Un
Nikon NSR-S307E XY-Link Controller Board 4S013-414-XYRLNK
Vero Monovolt PK60 Power Supply Unit ASM E3000 Lot of 2
Lumonics 6050035 PC Sense and Control Board Rev.A 2001035
TEL Tokyo Electron 3281-000147-12 PCB LST-1 3208-000147-11
Oriental Motor PK569AUA 5-Phase Stepping Motor Vexta New
KLA-Tencor M1 Mounted Assy L7 NNC AIT3 556556 New
KLA-Tencor Newport AIT2 Air Slit Assembly 393215 New
KLA-Tencor Nikon Box Door Opener 750-059211-001 New
WaFab ChemKleen Controller MPC-203
ATMI NOWPak SM4BKAFD-050812 Photo Resist Dispenser new surplus
SVG Station CPU Board PCB 99-80266-01
AMAT 0100-94006
AMAT XR80 Implant High Voltage Feedback 0090-91816 ITL
Bio-Rad 8946-001 VME/Overlay Interface PCB Quaestor Q7
KLA-Tencor CRS1010 Camera Lens Filter 002001
AMAT Applied Materials 9090-00668 Scan Optimization Module XR80 Surplus
Nikon EP-AX4 PCB Board 4S008-124
Kokusai Vertron Controller Unit CX1307
CTI-Cryogenics Retrofit Interface 8115266G001
LAM Research 853-012095-008 200mm End Effector New Surplus
Kokusai Vertron SIOB / A2 D1E013008 Control PCB
Kokusai Vertron Driver PCB PLMDRV4
SVG 90S Control PCB B9150011754
HVA Vacuum Rectangular Slit Valve 22211-0210
Hitachi S3-85001 Cosel Power Supplies P15, P-50 Qty 4
AMAT 0100-94006
产品名称: 噪声在线监测/取证系统
产品型号: ENS系列
基本参数: 无人值守,实时监控
产品介绍:
功能特点
全天候自动监测:防水、防尘、耐高/低温,24小时X365天不停机运行
定时监控:每天或每小时定时采集,采集时间和间隔可灵活设置
噪声限值监控:记录超过法定限值的噪声,不同时间段可设置不同的限值
可同时采集噪声分贝数值和现场高保真背景音频信号
可通过设置报警条件进行噪声事件管理
通过公网传输数据,组网容易,运营成本低
多重容错设计、性能稳定,硬件看门狗技术、永不死机
便携式轻便、小巧,便于携带和现场安装
灵活的数据查询和统计方式,支持噪声音频曲线回放
可集成GIS功能
性能规格
低功耗位嵌入式芯片(300MHZ),64M SDRAM(最大256M
2个标准端口,1个RS-485/422可选端口,4个USB口
10/100M 以太网控制RJ-45接口,1个并行口
高精度毫秒级实时时钟,支持掉电保护及看门狗功能
支持AC97音频接口,麦克风输入、线路输入/输出
工作环境:温度 -10℃~+60℃,湿度 5~90%,不结露
电源供电: DC 5V/1.2A(典型值)
参考的环境噪声标准
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
Hitachi 1-807883 PCB PM02-1 New
Fuji Seiki 1011018 Butterfly Valve Hitachi 3-821449
KLA-Tencor Objective Mount Assy. 760-321062-001
Hitachi Robot Swing Arm 200mm Unload 2-819447 New
TEL Tokyo Electron 3M10-311737-12 300mm Shower Spacer New
TEL Tokyo Electron Focus Ring 3D10-201599-V1
TEL Tokyo Electron Teflon Coil Cup WZ10-101255-11 New
AMAT 300mm Grooved Retaining Ring 0040-84056 new
AMAT Titan Head Membrane Support 0040-41846 new
AMAT 0100-94006
AMAT Titan SP Head 300mm Fixture Kit 0240-13190 new
Cybor Pneumatic Interface Control Module ADS660-00
AMAT 300mm Retaining Ring Grooved PL PPS 0021-17340 new
TEL Photoelectric Sensor Assy. 7100-0577-07 new
Lam Integrated Circuit Clamp Ring Upper Electrode
TEL Tokyo Electron Dark Space Shield Size 12 D124569-S new
Mitsubishi FR-Z024-0.4K Inverter Drive With FR-PUO1 Parameter Unit
Honeywell 060-3155-01 Display and Signal Conditioner NK Minor Case Damage
MKS Instruments 640A12TW1MA2F Pressure Controller 100 Torr New
AMAT 0100-94006
联系人:刘锦燕
手机:13295922579
电话:0592-5580706
传真:0592-5361191
邮箱:LJY_05228@163.COM
QQ:2711934024
QQ:2574619415
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
上一篇:Hitachi S-9300
下一篇:钨铼热电偶|迅鹏推荐
工控宝APP下载安装
